Landstar or Schinder
Discussion in 'Landstar' started by SPotts, Jan 27, 2019.
  1. SPotts
    SPotts Bobtail Member
    I've been an O/O for 13 years. Forced out if dedicated account. Need some help getting real info on each company.
  3. Buckeye 60
    Buckeye 60 Road Train Member
    1,229
    1,269
    Apr 19, 2018
    landstar you deal with agent's and get loads from them to start out you will be using a load board and calling them directly to book a load , you can build relationships with agent's and get loads that way . landstar doesn't own any trucks of there own or have loads of there own so you are not in competition with company trucks and the agents do not work for landstar they are independent contractors . you need to like dealing with people, from what I can tell there are more better paying loads in the landstar system but there also cheaper ones . you can make pretty good money just working the load board. the problem with the landstar system is dealing with the agents if your not used to dealing with people and different personalities. it's hard booking loads on the weekends or after buisness hours as most agents are closed , a few of the bigger ones operate 24.. 7 ... which helps some . it takes a little time to figure every thing out I think it's important to learn what loads not to take more than which ones to take . schnieder works off the computer and you find a load click on it and it's yours so no agent to deal with or hours to worry about . but schnieder has thousands of company trucks so you are in compitition with them ... from what I've seen of the Schneider load board the selection is not as good as landstars especially western States and the loads seem to pay mostly in the medium range ..... but on the computer click on method you are not building any type of personal relationships with agent's or even company personal which works better for some people. ... I think you can be successful at either one myself I am leased to landstar and very happy there . but found my way around there system easily. probably still a third or more of my loads come from the load boards . I have regular loads that I do and regular agents that I work for, and mostly use load board to fill in the gaps . I am at the point where I do 90%landstar loads and very few Brooker loads which actually haven't done one this year yet most of my problems have been with Brooker loads ( slow loading or unloading ect. ) some pay good but I just try to avoid them but they are needed at times. I couldn't imagine going back to a dispatch type system I am partial to landstar but if something happened here I might try schnieder
    TheDudeAbides and Mooseontheloose Thank this.
  4. Dave_in_AZ
    424,763
    Landstar is bad. Made over $120K last year after the smoke cleared and dust settled using company van.
    I'd go to Schneider.
    jethro712, stwik, elviscaprice and 3 others Thank this.
  5. Opus
    132,311
    I did $110 on $160, with 1 truck. And never touched a box, bag, bale, or pallet jack.
    I'd go to Landstar.
    Dave_in_AZ and kemosabi49 Thank this.
  6. Buckeye 60
    1,229
    1,269
    Apr 19, 2018
    actually go to Walmart and be a company driver
    Opus and jsnell Thank this.
  7. Dave_in_AZ
    424,763
  8. Opus
    132,311
    Remember, taco appreciation week.
    You'll never go wrong with appreciated tacos.
    Dave_in_AZ Thanks this.
  9. Dave_in_AZ
    424,763
    This is your FINAL WARNING!!!!
    GO TO SCHNEIDER.
    Do you want to fingerprint stuff like this?
    I do it because I hope to achieve a level of physical fitness equal to @tucker 's, and it's a MANLY thing to do, which makes me more like @IluvCATS .
    tucker Thanks this.
  10. IluvCATS
    IluvCATS Road Train Member
    4,089
    8,973
    Dec 1, 2014
    Seattle, WA
    83DEBE54-9046-4295-ADF7-D6A530FC1F85.jpeg I learned how to look manly from Dave.
    snowman_w900 and Texas_hwy_287 Thank this.
  11. Dave_in_AZ
    424,763
    One hour and 45 minutes in, and there is light at the end of the tunnel.
    Save yourself. Go to Schneider.
    Texas_hwy_287 Thanks this.
