Landstar?
Discussion in 'Motor Carrier Questions - The Inside Scoop' started by ds0082mn, May 14, 2026.
From the rumors, landstar is a place to thrive if youre not scared to drive and bend the rules a little.
Not a place to play by the books.
I know 2 roehl lease ops who finished their roehl contracts and immediately signed to landstar, because theyre so used to the mega carrier hand holding, they got placed on TONU so much they nearly lost their truck. One went back to roehl, the other went to another mega as an O/O leased to.ds0082mn and nextgentrucker Thank this. -
There is a steep learning curve at first, especially if you have never self-dispatched or used the Landstar system. It took me about three months to adjust, stop hating it, and build relationships with a few agents for regular work. At Landstar, you control where you go and what you haul, but no one is going to hold your hand.
Do not expect other BCOs to share their best agents. Landstar is highly competitive, and most people protect their own opportunities. You will also see some terrible load-board rates, including the same load posted by different agents at sharply lower pay.
At first, you will get a lot of calls and texts about available loads, many of them low paying. You are never required to take a load just because an agent offers it. To land good loads just from the load board until you build agent relationships, etc., you need to watch Landstar One closely and respond fast, because the best loads can be gone in seconds. The load alerts will be your best friend, but still not fool proof. You will have a few aggravating days where you call on newly posted loads, within a second of it posting, to only find its already been covered just that quick.
I disliked Landstar at first, but two and a half years later I am still here and doing okay. My best advice is to build direct relationships with a few good agents who can offer you solid loads. I mostly use the load board only when I need backhaul freight after one of those agents sends me somewhere. The goal is to have trusted agents call you with good freight, not to rely on random low paying load offers from bottom feeding agents, which are common, especially right after orientation once you get a trailer.snowlauncher, gentleroger, Speed_Drums and 6 others Thank this. -
####, sounds a lot...ds0082mn Thanks this.
Really appreciate the info
To follow up, for O/Os, what are the advantages/disadvantages of becoming a BCO for landstar v.s. staying independent or working through brokers, given the current freight market. How do the pricings and volumes compare? -
If you’ve never worked at a agent based trucking company there’s a learning curve you will have to learn.Some that have never worked for one tend to believe they always have loads going where they want to go and it doesn’t work like that often.And learning which agents have good freight and getting them to know you takes time it’s not easy in the beginning . As far as Landstar I have never worked there have pulled broker freight years ago and the guys I knew that were leased there and the way Landstar operated I wouldn’t want to
@Dave_in_AZ has a thread on here about Landstar somewhere
ds0082mn Thanks this. -
Here is the thread, OP, I think I am linking it correctly. It's the thread that @Sons Hero mentioned, I believe. Landstar So Far
Money is good, right now. Fair amount of BS. It's a spot market company with security clearances. Military moves. Ammunition explosives if you get back ground check. But van freight is spot market. Open deck hard to get a flat or step right now with the company. Do you have a trailer?
Wrong answer. Money is bad. Money is always terrible bad. Difficult system. Very bad terrible system. Most owners drop out in the first six months. High turnover. No good very bad 1099 company. Stay away.
