Leaking air at push fitting from tank.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by BlackThought, Oct 20, 2017.
  1. BlackThought
    BlackThought Medium Load Member
    566
    463
    Jul 22, 2014
    Memphis,TN
    Not an audible leak but produces bubbles when sprayed with soapy water. With the push fittings do I need to replace just the fitting and retrim the hose. Or just get a new fitting? Don't want to get bit in the ### by this in the future. Or can I keep the fitting and retrim the line
  3. tk40176
    tk40176 Light Load Member
    271
    154
    Apr 8, 2010
    Brooklyn, NY
    Replace with a brass compression fitting instead of half brass / plastic quick connect.
    baha Thanks this.
  4. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    I found that the way the fitting clamps the hose, it wears the plastic over time so that the hose becomes loose. You can first try just pulling out the hose and cut off about 1/4” and re-insert into fitting. Assuming you have enough hose.
    If it doesn’t work, then change the fitting.
  5. boneebone
    boneebone Road Train Member
    2,297
    2,372
    Mar 13, 2009
    There's a O-ring inside the fitting.
    You can use a needle nose plier and pull the brass outer release ring out and use a metal L-hooked pick to take out the old O-ring.
    Get a matching replacement O-ring, reinstall and reattach the airline.
    There is no need to trim the air line as the leaking is caused by the O-ring getting dried out and hardening, causing the air line not to seal properly.
    uncleal13 Thanks this.
  6. me myself and I
    me myself and I Heavy Load Member
    735
    312
    Oct 5, 2009
    vernon hills,Il
    The fitting will cost you 15 bucks. Get a pivoting one. If you want do do it on the cheap replace o ring. And trimming the line if possible wont hurt
  7. Ridgeline
    22,721
    123,352
    Replace it with brass, don't screw around with plastic.
