Leaking differential oil from the inter axle switch in the cab can one help
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Michaelk910, Feb 14, 2021.
  1. Michaelk910
    Michaelk910 Bobtail Member
    17
    11
    Feb 14, 2021
    I noticed gear oil leaking from behind the dash so I took the dash apart and noticed oil leaking from the actual lock and unlock differential axle switch can one tell me what could cause the switch to leak
  3. AModelCat
    166,493
    Drain your air tanks and see if there's oil in them. Could be engine oil in the air system from the compressor.
  4. mtoo
    mtoo Road Train Member
    1,942
    4,529
    Jan 15, 2011
    Retired on bended knee
    What @AModelCat says
    650cat425 Thanks this.
  5. Goodysnap
    Goodysnap Road Train Member
    3,811
    9,296
    Jul 12, 2017
    The orings are leaking in the differetial lock cylinder. Apply the lock and see if air is leaking into the differential indicating that fluid might go the other way.
    Also check the axle vent for plugged. If air cant escape as it warms, the pressure takes the path of least resistance and may be forcing fluid up to the switch.
    Gear oil has that special wang to it...
  6. jwsweet1979
    jwsweet1979 Bobtail Member
    20
    19
    Feb 14, 2021
    Diff lock solenoid is leaking. Do just as Goodysnap suggested. I've had this issue myself, just like you are describing.
  7. Michaelk910
    17
    11
    Feb 14, 2021
  8. Michaelk910
    17
    11
    Feb 14, 2021
    Where would the solenoid be located
  9. Michaelk910
    17
    11
    Feb 14, 2021
    What
    what did u do too fix it
  10. Cattleman84
    Cattleman84 Road Train Member
    10,057
    71,983
    Nov 1, 2017
    The Sticks, Idaho
    In the differential.
