Leaking fuel
Discussion in 'Volvo Forum' started by believe456, Oct 24, 2018.
  1. believe456
    believe456 Light Load Member
    191
    22
    Apr 22, 2015
    has anyone ever replaced a fuel line? Is this a easy fix
  3. benrab
    benrab Medium Load Member
    326
    238
    Apr 5, 2015
    Quebec ,Canada
    Depends of the year of your truck, since a couple of years the fuel line (nylon) for fuel supply and return are metric size and no std brass fitting will fit.
    Then you have to use original(new) plastic fitting, warm-up the end of the hose in very very hot water and push the fitting inside the new hose.
    Not easy to make a joint in the hose.
    Ben
  4. nasriza
    nasriza Road Train Member
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    its pretty simple need a heat gun to get those connections in and got to be carefull so you dont burn the hose just remove the line and you can buy line at dealer plus connections seperate. then heat up the hose with heat gun and put the fitting on it will be a very tight fit once it's on do the other side and you should be ready for install the rest gets held on by zip ties.
