Lease side quitting Prime advice.
Discussion in 'Prime' started by RunningAces, Jun 22, 2020.
  1. RunningAces
    RunningAces Road Train Member
    1,308
    2,588
    Jul 2, 2017
    Been with Prime going on 2 years on the flatbed side leasing with the standard walk away deal. I am about to be putting in my notice and was wondering is two weeks sufficient and if there is any other tips to make the process as smooth as possible I would appreciate it.
    Need4Speed Thanks this.
  3. Eddiec
    Eddiec Road Train Member
    2,333
    3,592
    Feb 2, 2015
    Two weeks is sufficient. Review your contract if you have not already done so. It should clearly state what the process consist of and what is required. Have the truck washed and detailed before you turn it in.
    RunningAces Thanks this.
  4. Cat sdp
    Cat sdp . .
    21,320
    76,354
    Apr 8, 2012
    Orion's Belt
    Forget your maintenance/tire fund......
    Bud A. and G13Tomcat Thank this.
  5. RunningAces
    1,308
    2,588
    Jul 2, 2017
    I keep my own maintenance fund outside of their nonsense. You're right about the tire fund though.
    Cat sdp Thanks this.
  6. bad-luck
    bad-luck Road Train Member
    3,449
    6,359
    Nov 16, 2013
    Baltimore, Maryland
    I think 2 weeks is sufficient. I also would take pix and video of the truck before you turn it in, and have a Prime employee inspect the truck. Hopefully they have some sort of inspection form you can both complete and sign. This will protect you, if damage is discovered later that you didn't do
    Newtrucker48 and RunningAces Thank this.
  7. nofreetime
    nofreetime Road Train Member
    1,271
    1,311
    Oct 22, 2013
    I've heard the leasing department recommend and invite drivers to schedule your truck inspection for when you plan to arrive to turn the truck in and BE THERE during the inspection so you can go over anything that would cause you to incur charges with the inspector and clear up anything you need to over those issues in person.
