Left Turn Signal Problem - Both rear lights flash
Discussion in 'Volvo Forum' started by ds1989, Sep 19, 2014.
  1. xsetra
    xsetra Road Train Member
    5,199
    7,151
    Aug 21, 2011
    Yep just troubleshoot like the others above say. If you have to pull all the bulbs. I4 sounds like one of your lights/pigtails the positive charge is shorting to your ground side.
    ds1989 Thanks this.
  3. ds1989
    ds1989 Light Load Member
    54
    38
    Jul 24, 2014
    Kansas City, MO
    Well, I have traced the problem to the plug at the inside back of the cab where the trailer pig tail connects. If I disconnect the pigtail from the harness plug the lights on the back of the tractor work correctly. As soon as I reconnect the pigtail the left turn signals flash again. Now I guess it's just a matter of determining where the problem, short, bad ground, loose connection, etc. is from that point forward....
  4. fortycalglock
    fortycalglock Road Train Member
    6,164
    6,613
    Jun 25, 2011
    Tourist Town, FL
    So if the pigtail is plugged into the truck but not a trailer, it does it, but if you unplug the pigtail from the truck as well no problem? But a new pigtail and problem solved
  5. fortycalglock
    6,164
    6,613
    Jun 25, 2011
    Tourist Town, FL
    Oh yeah, if you haven't done so in the last few years, change out the red and blue airlines as well. It really sucks when one cracks on you
  6. Alaska76
    Alaska76 Road Train Member
    1,228
    1,653
    Jan 20, 2014
    Inland Empire, WA
    If, when you do that and the bulb is still in the socket, it is most likely a shorted bulb. If the problem is present without a bulb in place, then it would be the socket.
  7. ds1989
    54
    38
    Jul 24, 2014
    Kansas City, MO
    Well, you are the winner! This was my problem. The red wire had two strands that were touching against the one next to it. Once I pulled those two strands away, problem solved! Thank you for your help...right on the money
