Let's discuss mpg. What do you get?
Discussion in 'Expediter and Hot Shot Trucking Forum' started by Menchaca0807, Sep 12, 2017.
  1. Menchaca0807
    Menchaca0807 Bobtail Member
    40
    4
    Mar 6, 2017
    what type of mileage are you getting on your trucks, tell me what truck they are and your trailer and load amounts and your speed I'm just curious
  3. Mark Kling
    Mark Kling Technology Contributor
    10,935
    4,216
    Sep 23, 2007
    Statesville, NC
  4. HotH2o
    HotH2o Road Train Member
    4,100
    4,868
    Sep 23, 2012
    My Silverado 2500HD gets 14.3 mpg if I keep it 65 or under on the highway.
  5. cjb logistics
    cjb logistics Heavy Load Member
    766
    643
    Aug 13, 2016
    Liberal Ks
    Gas ####, I anit putting gas in my ISX.
  6. Menchaca0807
    40
    4
    Mar 6, 2017
    what are you getting mpg wise towing a trailer with general freight on it dually truck
  7. AModelCat
    165,164
    I'm lucky to break 8 mpg with a 6.7L Powerstroke F550 loaded to 18,000lbs gross.
    HotH2o Thanks this.
  8. samcperez
    samcperez Light Load Member
    71
    61
    Nov 1, 2016
    According to my lie o meter I get 10.9 avg on my 2012 f-550 6.7 with 16ft box at about 17,500lbs but I do drive like an old lady compared with most
    Lite bug Thanks this.
  9. flatbedcarrier
    flatbedcarrier Medium Load Member
    667
    827
    Jun 8, 2005
    Southern California
    Our Owner Operators IFTA reports have averaged 10 mpg for many years now. The 2005 Dodge that I use to have , Cummings 2wd with 4:10 rear end gear ratio average 14 mpg. Wish I would've kept that truck. Bought a new one in 2015, 4wd, 3.73's and under a load it averages 10 mpg. I rarely go over 60 mph here in California. I wanted 4.10's but couldn't find any near where I'm based. The next truck will have them.
    We pull 3 axle Lowboys, 40' of deck space, and our loads weigh anywhere from 4,000 lbs upto 15,500 lbs.
  10. Pedigreed Bulldog
    7,737
    14,425
    May 7, 2011
    A 2wd pickup only has 1 ring & pinion that would have to be changed. You could buy the gearset you want along with all of the other items necessary for under a grand and do the swap in your driveway in a couple hours. Hell, add a locker or limited slip diff for a couple hundred more (if your diffs are currently open) while you're in there for the extra traction since it IS only a 2wd truck. Absolutely no reason to NOT have the specs you want when they are that easy to fix.
  11. flatbedcarrier
    667
    827
    Jun 8, 2005
    Southern California
    Im into jeeping, been down the gear swap road a time or two. My 2015 ram is a 4x4 and it's still under warranty. I'm in the office all the time these days so it's a low mileage truck, only have 40,000 on it right now. If I still have it when my bumper to bumper extended warranty is gone I may consider a re gear. That's only if I could buy a factory set though. The aftermarket gear sets these days tend to howl and growl.
