Lift axle valve
Discussion in 'Ask An Owner Operator' started by Marmon110P, Nov 26, 2025.
  1. Marmon110P
    Marmon110P Light Load Member
    192
    189
    Feb 24, 2019
    Hey fellas, so I've got a 12' spread axle suspension that I bought for a reefer. The front has a lift setup, but no valve. I bought a W&C valve and come to find out it wont operate till there's 30 psi at the solenoid. Who has a part # for an electric solenoid valve that will work with this at any PSI and also work with the leveling valve when down?? There's dozens of valves out there, I just don't want to keep spending $$ hoping its going to work.
  3. 062
    062 Road Train Member
    6,335
    33,977
    Oct 20, 2013
    Big Road Skateboard Thanks this.
  4. Big Road Skateboard
    7,161
    40,571
    May 2, 2021
    I've got the kit, but haven’t installed it yet. The kit didn’t include plumbing
    I'm hoping there's a one valve solution I can plumb into the front axle air bag supply, that will dump the air bags while diverting air to the lift bags, but I haven't looked for that valve yet.
    If not I'll plumb in a tee with a quick release on the supply side.
    I'm not sure on a single electric over air solution.
    062 Thanks this.
  5. Claytonbigsby
    Claytonbigsby Bobtail Member
    46
    112
    Mar 31, 2019
  6. Big Road Skateboard
    7,161
    40,571
    May 2, 2021
  7. Gridaxe5588
    Gridaxe5588 Light Load Member
    126
    168
    Nov 23, 2022
    Here's the valve I have in a tool box on the side of my Expedite Straight truck that I operate from a switch on the dash, the T handle is for manual operate operation which is required in 2 states.
