Lift axle
Discussion in 'Flatbed Trucking Forum' started by RHay, Jun 24, 2020.
  1. RHay
    RHay Light Load Member
    107
    17
    Sep 11, 2012
    I have a fontane 48' spread. My front axle has a lift for when empty. My question is is there a reason most spread axles I see lift the front and not the rear? I realize you would have some rear tail to be concerned about, but seems like it would get around much better in towns and tight roads.
    I've been contemplating moving the lift to the rear axle and relocating the leveling valve to the front. Then I would lose the ability to dump the rear when taking corners. My other thought would be to put a leveling valve on each axle to elevate that issue. Any advice or pros and cons, please share.
    RunningAces Thanks this.
  3. Phantom Trucker
    Phantom Trucker Medium Load Member
    381
    683
    Jan 11, 2016
    Calgary, AB
    With the front axle being a lift it adds a wee bit of weight on your drives. -Sometimes it's just enough to get you going again in slick/snowy situation in a yard or something.
  4. 201
    201 Road Train Member
    12,778
    26,291
    Apr 16, 2014
    high plains colorado
    I've seen that too, lift the front axle. Not sure why, I'd lift the back axle for the same reasons you say. Some people just do it different, I guess. Maybe it doesn't look cool. Might ride a bit better, but empty shouldn't be a concern anyway. I'd change it so the back axle lifts. Can't be that tough.
  5. bad-luck
    bad-luck Road Train Member
    3,432
    6,323
    Nov 16, 2013
    Baltimore, Maryland
    The front axle on a spread, as I'm sure you're aware of really tears up the tires. It is done to save the tires and make turning easier
  6. RHay
    107
    17
    Sep 11, 2012
    I'm aware of the front eating up tires but if you could lift the back and run on the front when empty it should get around better in town and tight places. Now loaded I'd still want to be able to dump the back axle. So I would need to move the leveling valve to the front axle
  7. brianv31
    brianv31 Light Load Member
    206
    515
    Mar 5, 2010
    IL I-74 mile 149
    Bulk trailers with a 4-2 tandem like a pneumatic or a tanker lift the front as well. I've thought the same as you, and lifting the rear instead of the front would make you legal in states with a short KPLA law. RGNs with a tri axle group lift the rear.
  8. bad-luck
    3,432
    6,323
    Nov 16, 2013
    Baltimore, Maryland
    As long as the front lift axle is not automatic like some of the newer trailers it goes down when you have, I think over 16K or something like that you can just keep lift down and put a dump on your rear axle that will pretty much accomplish what you are trying to do and not wear the tires very much
  9. bad-luck
    3,432
    6,323
    Nov 16, 2013
    Baltimore, Maryland
    A tandem lift axle is usually done to save on tolls as well as tire wear
    Speed_Drums and brianv31 Thank this.
  10. kwswan
    kwswan Road Train Member
    2,028
    11,083
    Jul 26, 2009
    mcminnville,tn.
    You don't have to move the leveling valve to the front axle
    The dump valve will still work on the rear with the leveling valve on the back axle.
    beastr123 Thanks this.
  11. Rontonio
    Rontonio Road Train Member
    6,484
    47,880
    Aug 9, 2009
    I will tell you that adding 10’ of tail swing going around corners in tight city spaces is going to be a much bigger pain the ### than having 10’ more inner bridge.
    I post this for my prospective
    this is like 14’ of tail swing ( maybe 2-3’ more than running on the front axle of a spread)
    I have seen guys wipe out cars in the left or light poles behind them in a tight u turn
    cke, Tug Toy, shawnhhllc and 3 others Thank this.
