Lift speed limiter
Discussion in 'Volvo Forum' started by Liquidforce, Jun 25, 2019.
  1. Liquidforce
    Liquidforce Light Load Member
    273
    285
    Sep 27, 2016
    Savannah GA
    I have a bunch of ex Penske Volvo’s, some are set at 70mph, some at 65, any way to lift the speed limiter without using PTT? I’ve tried through the dash, no good.
  3. Tb0n3
    Tb0n3 Road Train Member
    4,691
    9,476
    Oct 5, 2012
    Earth
    How much does the dealer want to change settings? I'm fairly certain that's the easiest route.
    Omega1 Thanks this.
  4. Omega1
    Omega1 Heavy Load Member
    721
    1,598
    Nov 18, 2017
    Oregon
    Did a quick Google search, this is a hot topic on the Volvos. I don't have the answer and I don't think there is an easy way. Looks like the ECM is password protected and set by the original fleet owner. I believe Tb0n3 response might be the best answer.
  5. DUNE-T
    DUNE-T Road Train Member
    7,015
    17,069
    May 10, 2015
    Detroit, MI
    PTT is the only way
  6. Grumppy
    3,175
    11,083
    Dec 11, 2010
    West Monroe, La
    If its a fleet owner (Penski) password protection, then you'll have to get with Penski & get the password from them. Its possible that you'll have to take it to a Penski service center so they can use their software that they used to install the password, so they can remove it.
    In other words the password may be incorporated into their software.
    If its a Penski password, Volvo service centers wont be able to access it (I dont think). So taking it to Volvo may not help you.
    The reasoning was so, that you couldn't take it to cousin Jim Bobs truck repair & have him to change the speed with a hijacked Volvo software....
    Or just simply get cousin Jim Bob from the Volvo dealer to change it for you. ONLY the Penski software could get into that setting with their software.
    I'll go a step further & say that I honestly don't know but, from what I got from Ryder while driving one of their lease trucks, that was my understanding.
    All I'm saying is check on it further. Hopefully some others here may be more helpful.
    Good luck.
    Studebaker Hawk and Omega1 Thank this.
  7. 401-Alex
    401-Alex Light Load Member
    258
    278
    Nov 25, 2013
    401
    Try 0000 all the way across its default.password. however just like my 05 I can set it in the dash but need the dealer to actually make it work
    KB3MMX Thanks this.
  8. Omega1
    721
    1,598
    Nov 18, 2017
    Oregon
    Yep...Same conclusion I have come to.
  9. Trucking in Tennessee
    Trucking in Tennessee Road Train Member
    3,740
    5,740
    Mar 19, 2018
    Nashville
    If you bought them from Penske give them a call, or even if you didn't. Either was they should steer you in the right direction.
  10. nasriza
    nasriza Road Train Member
    2,398
    2,074
    Feb 1, 2013
    Chicago, IL
    Two ways either go to penske to get the password or go to volvo they have a way to delete the password protection usually cost around 300 or so per vehicle
    KB3MMX Thanks this.
