Light Control Module in high voltage mode.
Discussion in 'Volvo Forum' started by xiipercent, Aug 16, 2014.
  1. xiipercent
    xiipercent Medium Load Member
    456
    129
    Mar 19, 2007
    Ok, scenario.
    Truck was parked for 3 months.
    Brought it back into service, batteries were still solid and reconnected all power and ground wires.
    Week 2 , the trans battery wire had poor connection. Stopped shifting. Replaced ring terminal, cleaned connection... all good.
    Now, since week 2, I've been getting this LCM hi voltage warning. It turns off the ac, DID flashes warnings.
    It has been intermittent. Once it came on and engine fan instantly came on. By the time i got a safe pullout,it had gone off. No errors.
    however, i need to figure which wires to inspect for abrasion/connection issues. Any guesses?
  3. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    CK. the ALT. to see what voltage it is giving out, reclean all ground wires
  4. driver442
    driver442 Bobtail Member
    7
    Check your Fuse on the Battery harness , corrosion had built up cleaned it replaced the fuse no problems .
