Lighting ground issue
Discussion in 'Freightliner Forum' started by W Bench Farms, Nov 9, 2021.
  1. W Bench Farms
    W Bench Farms Light Load Member
    211
    351
    Oct 16, 2017
    I have been having some weird light issues lately. Seems to be only when hooked to a trailer. Both trailers I use have mostly LEDs. When I hit the brake the right turn signal on truck lights up. If the turn signal is on as well, it will stop flashing when I hit the brake. Doesn't do it when the 4 ways are on. I'm leaning towards a ground issue. Going to check the plug on the truck side to make sure there's a good ground. Make me think it's there since it does it with both trailers. Anything else I need to look for? This is on a 95 FLD 120.
  3. QUALITYTRUCK
    1,819
    1,783
    Jun 14, 2009
    romulus,mi
    What you need to look for is year/make/model of truck and post it so someone has a chance to help you.....
    RocketyMan Thanks this.
  4. W Bench Farms
    211
    351
    Oct 16, 2017
    That would probably be a helpful idea. It's been a long week.
    1995 Freightliner FLD 120
  5. lilillill
    lilillill Sarcasm... it's not just for breakfast
    5,642
    13,472
    Nov 7, 2007
    Possum Booger, Alabama
  6. lester
    2,956
    8,085
    Jan 2, 2012
    NW, Iowa
    Make sure all your lights are working on the truck too. When I have a rear blinker/ brake light burned out or broken wire it does funny things. I also have to run incandescent lights on the rear of my tractor to make the flasher work with all LEDS everywhere else. Even tried the low voltage flasher and still wouldn't work right. 01 Pete.
    Long story short make sure all lights are working first
  7. W Bench Farms
    211
    351
    Oct 16, 2017
    Found the ground issue. Side marker/turn signal on the trailer was grounded to the mounting screw. Apparently this trailer does not have a ground wire from the plug to the trailer itself. Moved the ground on the light from the screw to the harness and haven't had a problem since.
    lilillill and lester Thank this.
