Lipe clutch problem
Discussion in 'Trucks [ Eighteen Wheelers ]' started by 24valve puller, Jul 31, 2018.
  1. 24valve puller
    24valve puller Medium Load Member
    399
    89
    Sep 8, 2007
    N.E. Oh
    Anybody ever had trouble getting the tranny out of gear while sitting still? This just started yesterday after a little horsing around. Still still has plenty of free travel and the clutch brake still works. Haven't had a chanch to get under there and check adjustment yet could it be that simple or is it something else. Clutch is only 6 months old and hasn't given any other problems and only 2 hard launches over the weekend
  3. benjamin260_6
    benjamin260_6 Medium Load Member
    433
    484
    Aug 8, 2012
    Ontario, Canada
    You probably broke some springs and they're getting jammed up in there. Those 2 hard launches were pretty expensive
    Bean Jr. Thanks this.
  4. Diesel Dave
    9,687
    32,974
    Jan 20, 2010
    Hesperia, Ca.
    That’s why I went with the Eaton’s 2050 easy pedal. Lipe has to be broken is correctly and are very touchy. The lipe wasn’t meant for my application. I did my research for quite awhile cuz I knew I was due for one within time and that time came.
  5. 24valve puller
    399
    89
    Sep 8, 2007
    N.E. Oh
    While I don't like it, I can put up with it. When you're looking to easily exceed the limitations of an Eaton clutch you don't have many options
    Diesel Dave Thanks this.
  6. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,735
    Jan 30, 2010
    keep stroking.
    Probably not the clutch. Shifter forks are worn or bent.
  7. Diesel Dave
    9,687
    32,974
    Jan 20, 2010
    Hesperia, Ca.
    @SmokinCAT knows of an individual that would built you a clutch for your application. He was on here explaining his clutches but I don’t recall who he was .....
    Edit; @superhauler might know who I’m referring too....
  8. AModelCat
    164,828
    My 15 speed was a royal ##### to get out of gear when I bought my truck. When I tore it open I found the interlock detents between the rails were rusted up from sitting, causing the rails not to slide properly. A twisted mainshaft can cause similar issues. I'm hesitant to say its a clutch considering you say the clutch brake works.
  9. 24valve puller
    399
    89
    Sep 8, 2007
    N.E. Oh
    If it was in the transmission shouldn't I notice something while I'm rowing through the gears? It's shifts completely fine it's just when you stop completely and go to try to get it out of gear
  10. ClineER
    ClineER Light Load Member
    229
    139
    Apr 27, 2016
    N.E. Oklahoma
    It could be the clutch, I was In a similar boat with a mid America clutch, i finally put in an eaton easy pedal even though it was only 20000 miles on the clutch. You can tell clutch is dragging if you look at it from underneath sand have someone stop the input then let up s little on pedal.
    A good releasing clutch may soon a little, one that drags the input will take of to full speed.
  11. SmokinCAT
    SmokinCAT Road Train Member
    1,773
    1,488
    Oct 20, 2010
    Hillsboro, OH./ Adrian, MI
    I don't know anyone that runs high HP that is still using a lipe, it is likely that even though it is a heavy plate load that when he launched it that it could have still slipped for a little bit, and in that time it started welding together.
