Lithium batteries for Electric APUs
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Tb0n3, Mar 31, 2021.
  1. Tb0n3
    Tb0n3 Road Train Member
    4,762
    9,695
    Oct 5, 2012
    Earth
    I've lived with International's EPU setup for 4 years now and it's been okay. My biggest complaint originally was they needed new batteries fairly often as their capacity reduced. I've had an auto start truck for two years now and that's been great, but the starting and stopping can be a bit annoying at times.
    I'm wondering if we, or the manufacturers could start making use of lithium battery tech for these electric apu setups. They make very large capacity batteries that can be repeatedly fully discharged without fully ####ting the bed like AGMs, and many are sized the same as group 31 batteries. That or have a compartment inside the heated interior for winter proofing them.
    Anybody have any thoughts to add?
  3. Arctic_fox
    4,676
    26,812
    Sep 16, 2016
    You can but the biggest problem is lithium batterys dont do well in extreme hot or cold, they lose a lot of efficency and cant provide or store nearly as much power as is on the lable. However, there are some you can buy that are designed with those conditions in mind but they are spendy to the tune of $850+ per battery when i looked into some for my RV. There are some more general purpose ones that are cheaper but i have no idea how they stack up compared to lithium batterys designed for extreme weather.
    AGMs more or less work anywhere. Plus they dont tend to explode in some conditions unlike lithium. I.E if you wreck or some swift ####### backs into you, or theres a short circut ect. Hence why they are prefered.
    Its doable but honestly for the 3 to 5 grand it would cost to go lithium you may be better off just getting a small genny or diesel apu.
  4. Tb0n3
    4,762
    9,695
    Oct 5, 2012
    Earth
    I was watching a video earlier that did a battle between lithium group 31 sized batteries and AGMs and I was surprised when they started talking about lead acid batteries being bad in the cold. Apparently they're just as bad as lithiums in some respects. They also had some testing on internally heated lithium batteries that used some of their own storage to heat the core. But that was my main reason for mentioning possibly storing them inside the envelope of the sleeper for temperature control while in use.
    This is the video I watched. I can't vouch for the guy's objectivity, but he claims to have a lot of experience designing power systems and goes through a whole boatload of testing.
  5. Arctic_fox
    4,676
    26,812
    Sep 16, 2016
    Thats why i mentioned that the lithiums designed for bad weather are spendy as hell and yes AGMs are just as bad in some ways in poor weather the main advantage is you can damage the lithium batterys in poor weather, AGMs dont care.
    And while you can keep them inside just keep in mind if something goes wrong they are closer to you and they burn HOT. Again not something that cant be overcome but im skeptical on the practicality.
    I love new tech but lithium batterys make me leery. But you asked for opinions and mine is that they can work but there are better solutions such as a generator with a low voltage auto start wired in for example. It can be done for a few hundred bucks and those small hondas are nearly silent compared to some APUs ive seen.
  6. brysol01
    brysol01 Medium Load Member
    320
    460
    Nov 2, 2009
    I looked into it and got $3400 each price and only warranty was 1 year So i did something different
    These were the lithium batteries talked to someone named Dave
    Reason for edit: Incomplete
  7. truckdriver31
    6,998
    8,363
    Sep 18, 2013
    call trojans tech support. they will tell you everything you need to know
  8. Jaebo74
    Jaebo74 Medium Load Member
    433
    1,864
    Feb 4, 2021
    LiFePo or LFP batteries are the answer, they can be had for $300 per 200 amp hour battery. Expensive but they'll last about 10 years under normal use.
    Good :
    More stable and more temperature stable
    Less toxic
    Longer life cycle
    Safer (less likely to self ignite under charge or quick discharge)
    Cheaper
    Bad :
    14% Lower energy density than normal lithium ion (ie: phone and tool batteries)
    Voltage is only 3.2v per cell as opposed to 3.7
    Lithium iron phosphate battery - Wikipedia
  9. Ridgeline
    22,789
    124,924
    One reason why these batteries don’t last in these apus is they are drained past their no return limits in other words past their depth of discharge limit of 50%.
    on top of this, they are bulk charged too quickly, so the life of the batteries are limited.
    Everyone jumps on the agm batteries wagon but they are just the same with the same limits.
    the best solution is to get a good old Diesel engine apu
    Or
    setup the charging system for the batteries that include a desulfurization unit with a computerized controlled regulator.
  10. tommymonza
    tommymonza Road Train Member
    4,519
    12,851
    Sep 10, 2013
    S.W. Florida
    My brother has a 40 foot Searay cruiser he has built a battery bank in of 6 volt golf cart batteries.
    He uses it to run the a/c unit for 12 hours at night when they anchor up away from shore power. Been with that set up for 35 years .
    The golf cart batteries have been the go- to for people in the sailing community for decades who want electricity for refrigeration and such.
    I'll ask him which brand as I want to build a system for my truck also.
