lithium batteries to save weight
Discussion in 'Ask An Owner Operator' started by 4hire, Oct 31, 2021.
  1. 4hire
    4hire Bobtail Member
    Oct 31, 2021
    AZ
    has anyone tried lithium batteries to save weight and can we run just 2 batteries?
    Last_over_hill Thanks this.
  3. Tug Toy
    Tug Toy Road Train Member
    7,148
    74,854
    Jul 4, 2015
    Corn field
    As long as your not somewhere that freezes. Have you priced a lithium battery? Regular wet cells are less than $80 each
    Without actually knowing I’m guessing a high quality lithium would be closer to $1000.00?
    You can get a Maxwell start battery and probably eliminate 2 of your battery’s but the maxwell will take up one of those spaces. So for like $700 you can eliminate one battery?
    But again, freezing is the biggest hurdle. Cars that have lithium battery have heating to make sure they work and not explode in freezing temperature.
    larry2903 and 77fib77 Thank this.
  4. Bean Jr.
    Bean Jr. Road Train Member
    5,580
    9,945
    Mar 30, 2014
    Actually the Maxwell would eliminate all batteries for starting. What is needed is a power source for the ECM, but that could be a motorcycle battery. The maxwell is the size of a battery, but if it weighs 1/10 of a group 31, I would be surprised! So you can eliminate the weight of 4 group 31, replace it with the weight of battery for a typical compact car, and have a much more reliable starting source.
  5. Ridgeline
    22,812
    125,432
    I use the maxwell starting module, it removes the starting power off the battery bank, most trucks that have this have two batteries, a few which have longer time between being on the road have three batteries. A few trucks are using Baldor regulators for the “house” batteries because of they are AGM batteries.
    i would never use li-po or any other battery in the battery box, in the sleeper yes because of the sleeper being insulated. A good bms would have a low temp cutoff which will stop the truck from exploding.
  6. scoobertdoo
    scoobertdoo Road Train Member
    1,512
    2,603
    Nov 11, 2020
    Dont bother, if you want to save weight, go with one battery, and tri pac, and a maxwell start super cap.
  7. scoobertdoo
    1,512
    2,603
    Nov 11, 2020
    BTW why are you working on saving 60 pounds?
    Bean Jr. and abyliks Thank this.
  8. '88K100
    '88K100 Road Train Member
    1,501
    3,688
    Aug 23, 2020
    The lithium batteries have to come down in price IMO..I priced lithium batteries for my own use,,,too much money considering I average 7 years out of a Walmart Marine Starting battery @$70.
  9. Old Man
    Old Man Road Train Member
    4,597
    13,471
    Apr 3, 2009
    Oklahoma City, OK
    Just leave the girl friend home.
    77fib77 and Oxbow Thank this.
