Lithium Starter Batteries
Discussion in 'Trucks [ Eighteen Wheelers ]' started by 1HeavySleeper, Apr 17, 2025.
  1. 1HeavySleeper
    1HeavySleeper Bobtail Member
    Apr 16, 2025
    Anyone have any experience with the IONIC lithium Heavy Duty Starter batteries?
    3000CA and 1800CCA is pretty impressive.
    Siinman Thanks this.
  3. Arctic_fox
    4,797
    27,410
    Sep 16, 2016
  4. Siinman
    Siinman Road Train Member
    5,654
    14,450
    Mar 5, 2017
    Kansas City, MO.
    I have two in my 23 VNL 860 and will never buy another kind of battery as long as these are around. Best batteries by far I have had and should be for the cost of them. I have the TriPac Envidia EPU that still has original batteries AGM. I can run my A/C and Fridge with anything on no problem for 15-24 hours depending on the sun and temps. Also have one solar panel that is hooked directly to the Lithium batteries.
    Any questions on them would be glad to answer and question you have. I might add a 3rd battery at some point but not really needed. These replaced 4 AGM starter batteries.
  5. Buckeyes614
    Buckeyes614 Light Load Member
    162
    162
    Jan 22, 2014
    Was just looking at these batteries and couldn’t find any reviews, I use 4 lead batteries 950cca that I keep replacing every 1.5 yr, I was wondering if I can just buy these 2 ionic batteries and call it a day, I only have my fridge and phone charger connected and ELD, but that’s about it
  6. Siinman
    5,654
    14,450
    Mar 5, 2017
    Kansas City, MO.
    Will work just fine. I have only two of these for the truck side and works great. Runs all my stuff no problem. I would recommend these in a heart beat. In winter time you might need to use the warmer on the batteries to start the truck. Once the batteries get to about 20 degrees they will crank no problems.
    Buckeyes614 Thanks this.
