Little Harbor Freight 1400W genny doing work...
Discussion in 'Ask An Owner Operator' started by KDHCryo, Feb 2, 2026.
  1. KDHCryo
    KDHCryo Medium Load Member
    642
    993
    Sep 14, 2023
    This little $525 genny has been keeping me comfortable for the last 2 years as an O/op.
    I got about 2300 hours on it now. Whole lot cheaper than a ThermoKing or Carrier or GreenAPU. Quieter too.
    I run Lithium batteries (LiTime 4x 100AH) in my electric APU bank, and Ionic Lithium (2x100AH) on my starter bank. Both get charged with the alternator, while running. I also added a Victron Smart charger that charges both banks up to 1500W, and the little Predator gets hooked in with a 120V 25A shore power plug.
    Usually in the summer I'm good for a 34 restart running the battery power APU bank for the fridge, microwave, coffee pot, lights, AC and house loads. Where I found I run into a problem is when I spend days at temps lower than 40 degrees, the Lithium BMS shuts down charging so they don't damage the batteries. They'll discharge down to 0F. When I get back over 40F they'll charge in 3 hours drivetime.
    The beauty of this little genny is 1400 W is enough to run the Espar Hydronic (which circulates coolant through the block), and run the house load even when the lithium's are shut down. Big motor is at 120F as coolant is warm.
    This little genny has cost me about $25 in gasoline over 2 days as I do my restart. Running the DD13 would've cost me $100 in diesel alone, plus emission issues.
    This summer I'm gonna add an Artic Fox diesel tank heater that runs on coolant so I don't have to buy Howe's anymore.
    https://www.youtube.com/shorts/J4DqX9535I
  3. Siinman
    Siinman Road Train Member
    5,532
    14,235
    Mar 5, 2017
    Kansas City, MO.
    You can always turn on the heaters on the starter batteries and it will start to charge them after the batteries hits about 30-35 degrees.
    I thought about adding the Espar Hydronic to my system but so far I have had no issues. Most issues in winter is when I park the truck for the weekend or longer on days off and it is cold as hell. Any other time in on the road I never have an issue. I shut down later in the night and back up in the 10 hours. So doesn't get too cold with Espar Heater running all night.
    FullMetalJacket, D.Tibbitt and KDHCryo Thank this.
  4. KDHCryo
    642
    993
    Sep 14, 2023
    Yep.
    To be fully Transparent and leave a good review.
    One of my Ionic 700AH has failed the app. Won't even recognize anymore. I contacted Ionic and they said send it back and we'll test it and send a replacement. They said 2 weeks turn around. I live in NC, they are in SC.
    I just jumped it over to my APU bank, and will not go with Ionic anymore.
    My next starter batteries will be Litime self heating, they've got a better rep.
    For a $700 starter battery I expected more. BattleBorn is having the same issues according to Will Prowse on the solar forum.
    My Litime APU bank has been solid, so I'm gonna go with them for self heated starters.
    Siinman, FullMetalJacket and D.Tibbitt Thank this.
  5. abyliks
    abyliks Road Train Member
    4,139
    9,748
    May 2, 2010
    ludlow MA
    Got my 2200 HF plugged into the block heater as I type this along with a 300w oil pan heater
    KDHCryo, Siinman and FullMetalJacket Thank this.
  6. Siinman
    5,532
    14,235
    Mar 5, 2017
    Kansas City, MO.
    Knock on wood. I have not had one problem with them. I also have never tried to update them either since it would not work when I first got them. Figure if it works no big deal.
    FullMetalJacket Thanks this.
  7. sbaumann14
    sbaumann14 Road Train Member
    1,241
    1,441
    Sep 1, 2010
    Rhinelander, WI
    As for the batteries…. My lithium’s have internal heaters but you could add external heating pads that automatically heat up the batteries. Do a YouTube search. Plenty of people have done it
    FullMetalJacket and Siinman Thank this.
  8. KDHCryo
    642
    993
    Sep 14, 2023
    Actually thinking of ordering some heat resistant tubing to channel hot exhaust down to the battery box. That would probably work pretty cheap
    Siinman Thanks this.
  9. sbaumann14
    1,241
    1,441
    Sep 1, 2010
    Rhinelander, WI
    Not a good idea. The fumes would b a problem to not only u but the drivers next to u. The pads r the way to go. Cheap. Easy to install. Run off the lithiums so there’s no draw on the house batteries.
  10. Ridgeline
    22,742
    123,697
    Oh hell no!!!
    Batteries produce something that is called HYDROGEN, and that is highly EXPLOSIVE.
  11. RunningAces
    RunningAces Road Train Member
    1,306
    2,584
    Jul 2, 2017
    I got pissed off at Thermokings prices so I stopped dumping money into the tripak black hole and bought a Predator 5000 super quiet and a 14000 btu dual hose AC. Put it on the catwalk with a rubber mudflap tossed over it and a couple two inch straps holding it down. Also, a lock and chain to keep honest men honest. Been using a simple 1500 watt space heater this winter and it has worked out great.
    I run a fridge off the 4 truck batteries during resets on the road and everything else off the predator. I wish I could go back and get all the money and time back I blew keeping the thermoking evolution running.
