Load air leak
Discussion in 'Ask An Owner Operator' started by Adriantx, Mar 21, 2021.
  1. Adriantx
    Adriantx Light Load Member
    64
    17
    Dec 29, 2018
    So I can hear a loud air leak come from behind the turbo area and around the billow pipe already had the billow pipe replaced and clamps as well as the gaskets on the dpf system but am still hearing the air only dose it when truck is on any one have any idea what it might be?
  3. lester
    2,957
    8,087
    Jan 2, 2012
    NW, Iowa
    Never hurts to also tell us what make, model, year and engine!!
  4. Spyro2112
    Spyro2112 Medium Load Member
    626
    436
    Mar 17, 2018
  5. Adriantx
    64
    17
    Dec 29, 2018
    2016 kw t680 cummins isx15
  6. slow.rider
    slow.rider Road Train Member
    2,005
    4,741
    Apr 4, 2017
    NYC
    Spray soapy water on everything until you see bubbles. Simple Green concentrate diluted like 98% works great.
    401-Alex Thanks this.
  7. Adriantx
    64
    17
    Dec 29, 2018
    Already did that dont see nothing but can hear it
    slow.rider Thanks this.
  8. Adriantx
    64
    17
    Dec 29, 2018
    Already did that cand see nothing no bubbles but I can hear it
  9. SteveScott
    SteveScott Road Train Member
    4,897
    16,809
    Nov 10, 2015
    Find a level spot when you can park with the brakes disengaged. Turn off the engine then head back and listen where it's coming from. If it's that loud, you should find it pretty easily. Also would hurt to block a wheel with something like a big rock if you don't have a wheel chock.
  10. 062
    062 Road Train Member
    6,344
    34,002
    Oct 20, 2013
    If it’s only leaking when the truck is running it may be the fan hub. Do you have a manual fan switch? If you do flip the switch and see if the leak stops.
  11. skallagrime
    skallagrime Road Train Member
    3,855
    9,928
    Apr 10, 2012
    Indiana
    Picture of vicinity, noticed youve also got gutless transmission on hookup, might be a leaking air shift line?
    baha Thanks this.
