Load configuration
Discussion in 'Flatbed Trucking Forum' started by Rgulack, Oct 11, 2020.
  1. Rgulack
    Rgulack Bobtail Member
    Hauling lumber out of BC to NE Washington. 53’ four axle trailer, 105,500 GW. Load is 10 twenty foot units, 40’ on bed, 20’ on top, average overall height 13’, avg GW 100,000. What is best configuration for maximum stability. I try to center the loads on the trailer. Would I be better off with the weight farther back? Farther back reduces overall height and center of gravity.
  3. Roberts450
    Roberts450 Road Train Member
    2,237
    3,638
    Feb 6, 2016
  4. Long FLD
    Long FLD Road Train Member
    12,902
    54,118
    Mar 4, 2015
    Does the load have to be tarped? If not I’ve found that the ride is better loading the ends of the trailer, it takes that buck out of it compared to loading 40ft right in the center. This load below is 20’s, the half unit on top may have been an 18 for weight I can’t recall for sure. But this is how we hauled long stuff back to a triad plant that didn’t need tarped. And provided you can load like this and have your weights right for Canada and the States this is how I’d suggest.
  5. HillbillyDeluxeTruck
    5,957
    30,493
    Mar 3, 2013
    San Antone
    Whats the weight of the lumber itself?
    cke Thanks this.
  6. Long FLD
    12,902
    54,118
    Mar 4, 2015
    Just guessing I would say 65-66k. You can only go 101k in Canada on 6 axles.
    cke, Rugerfan and HillbillyDeluxeTruck Thank this.
  7. Long FLD
    12,902
    54,118
    Mar 4, 2015
    Looking back through my phone I split a lot of no tarp loads. We used to run these like this because the stickers weren’t banded to the unit and it was a pain in the rear trying to pyramid them to stretch the load out.
  8. okiedokie
    okiedokie Road Train Member
    13,906
    110,234
    Jun 13, 2011
    PNWET
    I'm confused. That looks like a 8 axle.
  9. ZVar
    ZVar Road Train Member
    10,911
    23,833
    Sep 10, 2010
    Flint, MI
    At least in MI, when you say 6 axle or 8 axle you are talking about only the trailer. If someone was to ask me I'd call that a 4 axle. Yes it's not quite accurate as it only counts the trailer, but around here in MI even our 8 axle trailers rarely use a tag axle on the power unit.
    cke and okiedokie Thank this.
  10. okiedokie
    13,906
    110,234
    Jun 13, 2011
    PNWET
    Ok. It's a regional thing. Thanks for the clarification.
    cke Thanks this.
  11. Long FLD
    12,902
    54,118
    Mar 4, 2015
    Lift axles have to be in the air in Canada. So 3 axle truck and 3 axles on the trailer north of the border, then drop the 2 lift axles in the States.
    cke, D.Tibbitt, Rugerfan and 1 other person Thank this.
  12. okiedokie
    13,906
    110,234
    Jun 13, 2011
    PNWET
    Really. What's the point of having drop axles. Just so you can legalize your bridge weights in US?
    cke Thanks this.
  13. Long FLD
    12,902
    54,118
    Mar 4, 2015
    Yes. In Western Canada you can’t have manual control of lift axles. In the States you’d be about 88k or so gross on 6 axles out west. With 8 you can bridge about 105k. Canada let’s you go 101k on 6 so it’s a happy medium.
    cke, 650cat425 and okiedokie Thank this.
