Load information compliance on eld
Discussion in 'Questions From New Drivers' started by Tracybradley, Feb 2, 2025.
  1. Tracybradley
    Tracybradley Bobtail Member
    6
    Jul 13, 2018
    Wanting to know if im hauling the same load for multiple
    Days do I need to enter load information and trailer number on my eld every day I'm under that load. Are if I enter it the day I pick it up the number stay the same until I change loads.
  3. Flat Earth Trucker
    4,316
    16,622
    Nov 19, 2018
    No.
    Your load has a pick up date and an ending date. Upon reaching the end date you set in the eld, you will need to select another pick up date (which is no earlier than today's date) and another end date with load number, trailer number, and bol number.
  4. Long FLD
    Long FLD Road Train Member
    12,906
    54,138
    Mar 4, 2015
    Probably depends on the ELD. The two systems I’ve used (Motive and Geotab) once you enter the info it stays until you remove it.
    prostartom and Bean Jr. Thank this.
  5. Brandt
    Brandt Road Train Member
    4,626
    6,361
    Sep 17, 2012
    You need the trailer number and load info on every log for every day. Like others said it depends on on your ELD setup. The 3 different one I have used all carry over all the information to the next day. So the only time I had to change it was when I switched trailers or unload and get a different load.
  6. flood
    flood Road Train Member
    4,168
    4,047
    Dec 25, 2010
    Again it depends on the eld. Mine has start and end date
  7. Cdemars316
    Cdemars316 Road Train Member
    1,043
    6,766
    Nov 10, 2018
    Motive you can go into the settings and make it so it doesn't carry over, I drop and hook alot and am switching loads at least twice a day, so for me that works, if you have it set to carry over then it will carry over all info until you go in and change it when you drop that load you were under
    bryan21384 Thanks this.
