Load Weight
Discussion in 'Questions From New Drivers' started by rookiedriver93, Aug 21, 2019.
  1. rookiedriver93
    rookiedriver93 Bobtail Member
    13
    7
    Mar 29, 2014
    So I've never been over on my weights. Ever. Until now. 40 lbs over on my drive with no room to adjust . How strict is dot ?
    11,880
    34,040
    26,240
    Topped off in fuel. Nearest scale is about 170 miles away on I59/I20 West in Toomsomba leaving Bama entering Ms .
    blairandgretchen Thanks this.
  3. tmb0507
    tmb0507 Medium Load Member
    357
    197
    Aug 11, 2012
    Folkston, GA
    Run it you will burn the weight in fuel and for 40 lbs there not going to say anything
  4. truckdriver31
    6,998
    8,363
    Sep 18, 2013
  5. starmac
    starmac Road Train Member
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    40 over is on;ly over in Colorado. lol
    skellr and rookiedriver93 Thank this.
  6. skellr
    skellr Road Train Member
    8,735
    12,187
    Jul 17, 2011
    The Village, Portmeirion
    It depends on the situation. You usually have quite a bit of leeway (in practice). It depends on who you are dealing with.
    weigh in motion scales aren't very accurate so they give quite a bit of leeway, it usually takes a couple-few k over for them to flag you in to stop on the scale for an "accurate" weigh.
    Depends on who is checking and what mood they are in.
    Technically, you are overweight on an axle or group. They could give you a ticket for it, but usually you would need to provoke them into doing it. And if they do just give you an overweight ticket, just eat it and move on. It's the least evil of the evils out there. You give them a hard time and they will find some obscure thing to give you a failed inspection in addition to being "overweight", you don't want that.
    They aren't that strict with weights. They only real time they are is when you do something you shouldn't. Get caught on a restricted road or bridge, give them attitude.... Then they will pile on everything they can find to write you up for.
    I wouldn't worry about 5-800lbs over, but that's just me, it also depends on where i'm running. Burning fuel also reduces weight. Sure, I might get a ticket for it, but it's faster to pay the ticket and keep on moving than to wait around and have the load reworked. reworking the load is usually more expensive to me, out west anyway. not "mid-west" but west coast, well, maybe not Washington State...
    gentleroger and rookiedriver93 Thank this.
  7. WesternPlains
    6,370
    57,466
    Sep 1, 2017
    Rapid City, SD
    Your weights are ok. That could be explained in tolerance of the scale. Or even wind.
    Co. allows 35k on tandems. As long as gross of 80k isn't over.
  8. Concorde
    Concorde Road Train Member
    5,506
    19,599
    Jun 29, 2016
    West Melbourne Florida
    Slide your drivers seat 2 clicks forward..
    Seriously, you are good to go.
  9. Linte_Loco
    Linte_Loco Road Train Member
    1,618
    6,485
    Apr 24, 2011
    LA (lower Alabama)
    40 lbs over in MS? Dead meat
    Criminal
    J/k. You’re good. You’ll burn that off in no time
  10. WesternPlains
    6,370
    57,466
    Sep 1, 2017
    Rapid City, SD
    :laughing-guffaw:
    Boost the steers to 13k? :laughing-guffaw:
  11. Oor
    Oor Road Train Member
    1,374
    3,538
    Jan 11, 2012
    Example.
    170 miles at 7 mpg = 24.28 gallons
    24.28 gallons at 7.1 lbs per gallon = 172.10 lbs.
    All comes off the drives, you'll burn the weight before you get there.
    Learn the math driver.
    Useful when you need to be careful how much fuel to put on.
