Loading problems
Discussion in 'Questions From New Drivers' started by tom horn, May 17, 2020.
  1. tom horn
    tom horn Bobtail Member
    7
    May 17, 2020
    Howdy from Oklahoma everybody. Boy did work get screwed up I can't get a load anywhere. So while I am sitting around playing with myself I decided to look at why my truck loads so slowly. I have a Troxell 130 barrel and it only pulls 10lbs or inches vacuum and takes at least 30 minutes to load. . The vacuum pump has been replaced and the pump on the tranny has been replaced. Now the mechanic says the pump motor on the vacuum pump is bad. So I have already thrown a Lot of money at it and fixed nothing. Is it possible my scrubber is bad> ? I can't see paying him again and maybe not help i t Again. Any advice would really be appreciated this is my truck and I need to save all I can especially now. Thanks in advance
  3. MACK E-6
    50,050
    238,520
    You pull a dry tanker, I take it?
  4. tom horn
    7
    May 17, 2020
    No I haul salt water oil patch loads
  5. Western flyer
    Western flyer Road Train Member
    2,807
    6,797
    Mar 13, 2014
    30 minutes to load, shouldn't keep you from getting loads.
    That's about what it took us 6 /7 years ago when I
    Was out there loading water.
    I don't see that as a problem, since your usually loading
    In the middle of nowhere by yourself.
    Your not holding anybody up by not loading in 15 minutes.
    Everything being piped in and the oilfield in the crapper
    Is why you're not getting any loads.
    WildTiger1990 and alds Thank this.
  6. Roberts450
    Roberts450 Road Train Member
    2,237
    3,638
    Feb 6, 2016
    30 minutes to load how much? 30 gallons or 3,000 gallons? Did it used to load faster and have higher vacuum? You listed pounds but also inches, inches of what?Have you changed any hydraulic filters? We need more details.
  7. WesternPlains
    6,369
    57,394
    Sep 1, 2017
    Rapid City, SD
    30 minutes for 130 barrels doesn't sound bad at all. In fact, pretty good.
  8. Moosetek13
    Moosetek13 Road Train Member
    14,985
    19,038
    Nov 1, 2010
    Burnsville, MN
    (snip)
    I think I'll forego all my comments that I just wrote, because on reflection they all seemed to sarcastic and judgemental.
    But I will say this one thing...
    I think the OP needs to find a more competent mechanic.
  9. HillbillyDeluxeTruck
    5,957
    30,492
    Mar 3, 2013
    San Antone
    When he says 130 barrels, is he talking 55 gallon barrel size?
    I dont know jack about that stuff, but I know a mechanic that does.
  10. Roberts450
    2,237
    3,638
    Feb 6, 2016
    Barrel is the standard unit of measurement in the oil industry. A barrel is 42 gallons so a 130 barrel tanker actually has 5460 gallon capacity.
  11. HillbillyDeluxeTruck
    5,957
    30,492
    Mar 3, 2013
    San Antone
    Ah, I think I remember being told that in the past now. Call me nuts but 5240 gal of brine water in 30min doesnt seem too bad.
    Roberts450 Thanks this.
