Loading & transporting 32ft-40ft Logs
Discussion in 'Flatbed Trucking Forum' started by GENTNERDUNN, Aug 1, 2018.
  1. GENTNERDUNN
    GENTNERDUNN Bobtail Member
    7
    Aug 1, 2018
    Anyone have experience with transporting logs on flatbeds? The requirements, safe practices, etc.? Can the driver just use pipe stakes or some type of side rail? I have a FTL project coming up potentially transporting logs from Herber City, UT→ OR and Whiteriver, AZ→OR. I also have no idea how to find drivers specializing in this field either around these locations. Any advice or help would be appreciated! Thanks.
  3. ashtre
    ashtre Light Load Member
    109
    108
    May 9, 2016
    I hauled em once used pipe stakes and they had us chain the stakes together about halfway up
    Tb0n3 Thanks this.
  4. GENTNERDUNN
    7
    Aug 1, 2018
    How high or large were those pipe stakes? As tall as the logs were?
  5. ashtre
    109
    108
    May 9, 2016
    No the logs were higher by maybe 3 or 4ft, so i used just about every strap i had like i usually do
    GENTNERDUNN Thanks this.
  6. GENTNERDUNN
    7
    Aug 1, 2018
  7. ashtre
    109
    108
    May 9, 2016
    They arent very large i've seen some sturdier ones, one of mine actually bent a little when getting unloaded
  8. GENTNERDUNN
    7
    Aug 1, 2018
    Yeah I have seen that some people truly just make there own so I guess it just depends on the amount of stress someones pipe stakes can handle
  9. Espressolane
    18,693
    117,180
    Can you be a bit more specific about what these logs are. There are a few ways the loads could be prepped. That could make a bit of difference.
    Using pipe stakes will work if they are sturdy. Best to use log bunks. Some places will rent them.
    This place makes bunks for flatbeds, scroll down about middle of page.
    Log Truck Equipment
  10. GENTNERDUNN
    7
    Aug 1, 2018
    I think they are Ponderosa Pine Logs. Each load is roughly 45,000 lbs I think. I will check out that link too thanks!
  11. Espressolane
    18,693
    117,180
    What is the load site? At drag line or site mill or?
