Loads heading to CA
Discussion in 'Questions From New Drivers' started by Sixela918, Feb 18, 2023.
  1. Sixela918
    Sixela918 Light Load Member
    257
    397
    Nov 24, 2021
    Phoenix, AZ
    Do shippers actually load trailers that are going to CA differently, to account for CA's 40 foot rule?
    ducnut Thanks this.
  3. dngrous_dime
    dngrous_dime Road Train Member
    3,150
    5,765
    Jan 28, 2014
    Lansing area, MI
    Awfully bold of you to assume that shippers even know how to properly load ANY trailer. They generally have zero clue about laws, unless they're shipping hazmat. I've even had some that didn't realize I needed a BOL.
  4. InTooDeep
    4,981
    37,363
    Jan 17, 2016
    Carmichael CA
    Most do some don't have a clue
    Oxbow Thanks this.
  5. REALITY098765
    REALITY098765 Road Train Member
    1,520
    1,350
    Sep 17, 2017
    A BOL is the carriers responsibility, not the shippers.
    Most shippers make 1 out for the carrier though, but technically it's up to the carrier.
    jcatel and D.Tibbitt Thank this.
  6. ducnut
    ducnut Road Train Member
    2,683
    8,131
    Dec 31, 2010
    SPI
    My previous employer loaded differently. They had a pallet scale that attached the weight to the pallet’s bar code. One of the shipping leads was very good at laying out pallets, so the trailer would axle out legal. They had a platform scale to verify, as well. Great place to work.
    Oxbow, Siinman, Concorde and 3 others Thank this.
  7. Sixela918
    257
    397
    Nov 24, 2021
    Phoenix, AZ
    The reason I ask is I've had loads going to Cali that were over on the trailer tandems at the 40 foot mark. I had to move the tandems back a few holes to get under 34k and hope the weigh station (if I couldn't avoid it) doesn't really notice or care that the tandems were back a little past the 40 foot mark. BTW, my truck steer axle is rated for 12k so I don't have much help by moving the fifth wheel forward.
  8. bryan21384
    bryan21384 Road Train Member
    15,745
    34,325
    Sep 18, 2009
    Memphis, TN
    Not always. I took meat from Marshalltown, IA out to California. The load was 43k. The wheels were a couple of holes behind the 40 foot mark. Ran it out there anyway. Crossed the scale and kept it moving. It was late when I ran that way.
    ducnut Thanks this.
  9. nredfor88
    nredfor88 Road Train Member
    1,801
    6,100
    Sep 26, 2019
    USA
    I've taken many loads into Cali. My experience is that any shipper that does CA loads regularly will get it right. You are likely only to encounter issues if the shipper does CA loads on a very irregular basis.
  10. ducnut
    2,683
    8,131
    Dec 31, 2010
    SPI
    Sliding the 5th wheel forward has zero affect on tandem weight.
    Look at your steer tire weight rating and use that as your front axle weight guideline. My door sticker doesn’t have a steer axle weight rating on it, but, I’m over 12K, when I’m at 34K on the drives. I’ve not been bothered.
    scottied67, Oxbow and gokiddogo Thank this.
  11. Sixela918
    257
    397
    Nov 24, 2021
    Phoenix, AZ
    Not trying to say you're wrong but.... You're wrong. Moving the fifth wheel forward absolutely affects the trailer tandems - by shifting the weight from the tandems to the drives.
    Truckingdaytrader and tscottme Thank this.
