locker axle
Discussion in 'Freightliner Forum' started by Glenn West, Jun 19, 2020.
  1. Glenn West
    Glenn West Light Load Member
    88
    37
    Apr 22, 2016
    As some may remember my truck is for personal use. Tow my 21k fith wheel camper. I singled it. Used rear axle in mid position. I would like to change out axle and add a locker unit for added traction off road. I have not had to be pulled yet but barely got out. So have anyone done this. I searched salavage yards on line and found complete units but no mention of locker.
  3. AModelCat
    164,925
    When I converted my W900A from tandem to single, I just drove to the nearest wrecking yard. We walked the yard until we found an axle that fit my criteria.
    I'm not up to speed on axles but if you can post your axle model #, someone might know if you can re-use your existing housing and just replace the carrier and 1 axle shaft.
    magoo68 Thanks this.
  4. magoo68
    magoo68 Road Train Member
    3,393
    5,385
    Jun 11, 2011
    st malo mb canada
    Many Canadian trucks use 4 way lockers . Maybe you can find one online at a Canadian wrecking yard to get the axle needed .
  5. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    The axle housing has a slot in it for the locker, its best to buy the complete locker rear/end from used parts place?
    AModelCat Thanks this.
  6. Glenn West
    88
    37
    Apr 22, 2016
    I understand my housing can be used. Have to grind out a place for it.
