long idle on new cascadia
Discussion in 'Schneider' started by Silverking, Jan 23, 2014.
  1. Silverking
    Silverking Light Load Member
    102
    60
    Nov 7, 2013
    Edgewater, FL
    anyone leave these new trucks idle for 2 days straight? We got single digit lows all weekend here. Idled 14 hrs last night and had to regen when I got to the truck this morning. So wondering what happens if not there to do the regen. will the engine shut off? Don't want to get to work Monday with the truck off and froze.
  3. P51-D
    P51-D Light Load Member
    72
    20
    Jan 25, 2008
    My truck
    My 2011 would only idle between 7 and 9 hours before it would shut down and I would have to do a regen. On the plus side it was like a built in alarm clock cause it would wake me up when it shut down.
  4. Silverking
    102
    60
    Nov 7, 2013
    Edgewater, FL
    this is a brand new daycab.. so wont be waking me up lol
  5. russtrucker
    russtrucker Road Train Member
    1,767
    337
    Mar 27, 2012
    Central PA
    I drove Cascadia. When shut down the truck, I turn on ParkSmart. That's what apus are for to reduce idle.
  6. moosc
    moosc Road Train Member
    3,284
    1,172
    Mar 5, 2009
    Lincolnton NC
    After around 10hrs the truck will regen by itself. I've been woken because it sounded like a jet engine taking off. If your in a day cab don't leave it running plug it in.
  7. moosc
    3,284
    1,172
    Mar 5, 2009
    Lincolnton NC
    Parksmart is junk in winter all u have is standard bunk heater. And when it goes 10 or colder u should b idling any way.
  8. russtrucker
    1,767
    337
    Mar 27, 2012
    Central PA
    Once it runs out of battery, needs engine power to charge.
  9. ethos
    ethos Trucker Forum STAFF Staff Member
    4,287
    14,273
    Mar 3, 2013
    Fort Worth
    He wants to idle the engine because of the cold. So his fuel doesn't gel among other things.
  10. Newtothis25
    Newtothis25 Bobtail Member
    17
    6
    Sep 9, 2013
    If its a day cab plug it in and make sure you have anti gel in your fuel and you'll be good to go. I like in Northeast PA and have been greeted with the same lovely weather and our trucks are fine with the above mentioned things listed.
  11. dieselfuelonly
    dieselfuelonly Road Train Member
    2,475
    5,086
    Nov 12, 2012
    Chapel Hill, NC
    Never could figure out a trick to make the Cascadias stay idling. On my Century I would take a CB antenna (a wooden dowel would work better, but I had an extra antenna for some reason) and vicegrips, run the cb antenna through the steering wheel against the throttle until it showed about 11% throttle application on the diagnostic output on the Qualcomm, then use the vicegrips to hold it in position. Worked perfectly LOL. Couldn't trick the Cascadia though.
