Lookin over the Hood, on the way home from my last trip.
Discussion in 'Trucker Videos' started by Mr. Cob, Jan 10, 2019.
  1. Mr. Cob
    Mr. Cob Light Load Member
    Howdy All,
    Nothing special, just little video I took and found when going through the photos of my last trip, if you don't like Classic Country Music, turn your speakers OFF.
    Dave
    Vampire, 7-UP, D.Tibbitt and 4 others Thank this.
  3. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    It shows unavailable.
    Maybe I can try going to the source link and seeing there.
    Mr. Cob Thanks this.
  4. Mr. Cob
    Howdy x1Heavy,
    I have it posted on youtube, it shows up on my computer, I did the embed thing from youtube. If your not seeing the video maybe I have to paste a direct link, I'll edit the first post to include a direct link.
    Dave
    x1Heavy Thanks this.
  5. x1Heavy
    34,016
    42,144
    Mar 5, 2016
    A direct link is welcome. No problems. I would not mind a old ride in a pete one more time even if it's by video.
    Thank you for what you have done.
    D.Tibbitt and Mr. Cob Thank this.
  6. Mr. Cob
    Howdy x1Heavy,
    Is it working now, I am about worthless with anything electrical or that involves computers.
    Dave
  7. x1Heavy
    34,016
    42,144
    Mar 5, 2016
    Ok what I did is pull the address off your embed. This next sentance IS the actual link to the video. You can copy JUST THAT LINE and put it anywhere in your next post or up top in the first one as you edit. It should be built by TTR site as a living link in blue.
    The video itself is live and running on you tube
    edit, give me a minute to consider the problem.
    ht*tps:/*/youtu.be/Xp5aCH70sDA
    REMOVE the * from the two spots I placed to "Break" the link and it should now work once you eliminate the spaces left behind.
  8. DL550CAT
    DL550CAT Road Train Member
    1,427
    1,486
    Oct 18, 2009
    Waynesburg, Pa
    Better get that charging system looked at. Volt gauge is off or you got trouble brewing.
  9. Misesian
    Misesian Road Train Member
    2,078
    3,178
    May 21, 2014
    Nothwest Arkansas
    +1 for running a ScanGuage. I recommend it, especially if you’re running a stripped down company truck with no gauges.
  10. Mr. Cob
    Howdy DL550CAT,
    I have now driven the truck over 20,000 miles since I finished the RV conversion, the volt meter has always shown the reading is shows on this video, every now and then it will go up to 13 but rarely. The lights are bright, the truck has always started, the alternator checks, brand new batteries when I started the build last year out good. That said I am open to suggestions. Thanks for any advise you can offer.
    Dave
  11. Mr. Cob
    Howdy Misesian,
    I use the scan gauge mainly to keep an eye on fuel mileage, boost and engine load, and to verifiy that the actual gauges are reading correctly.
    Dave
