Looking for D8T weight and width blade angled
Discussion in 'Heavy Haul Trucking Forum' started by MartinFromBC, Jul 6, 2019.
  1. Macneil
    Macneil Heavy Load Member
    711
    426
    Dec 15, 2010
    Sudbury, ON., Canada
    I’ve got the winch idea down but pardon me for asking, what is this arch you speak of? I am very confused lol.
    I also agree that at 12’10” full width you should be able to sneak it in under 12 without any hassle.
    Oxbow and MartinFromBC Thank this.
  3. truckdad
    truckdad Road Train Member
    2,075
    17,195
    Dec 14, 2014
    Penn Valley, CA
    I think he is referring to "sweeps"
    Oxbow Thanks this.
  4. MartinFromBC
    2,769
    12,484
    Oct 19, 2018
    An arch is a couple pieces of steel that go up at an angle, a few feet higher than the winch, with a roller at the top, the cable goes up and over it, so it hhas a lifting effect. Lifts the end of the log so it skids easier, and doesn't catch on everything.
    Oxbow, Cat sdp and truckdad Thank this.
  5. MartinFromBC
    2,769
    12,484
    Oct 19, 2018
    This is not even a D8, just a random internet pic to show what an arch is.
    Also the guy who owns it is very elderly, and doesn't run equipment any more, but he got a hold of his operator finally, has been trying to for days, the operator was away camping.
    The operator said the winch and arch weighs just slightly less than a ripper, and yes it will at full angle be under 12 feet wide. So it's on for Wednesday to go get it. [​IMG]
    Oxbow, REO6205 and truckdad Thank this.
  6. truckdad
    2,075
    17,195
    Dec 14, 2014
    Penn Valley, CA
    Ok. I've seen that. Thanks Martin
  7. MartinFromBC
    2,769
    12,484
    Oct 19, 2018
    Sorry guys I thought I had figured out how to post a picture, but apparently not.
    Oxbow Thanks this.
  8. REO6205
    REO6205 Road Train Member
    13,168
    60,501
    Feb 15, 2014
    California.
    Thanks for the weight info on the winch and arch versus the rippers. I've never hauled a big Cat with rippers so I was just going on guess.
  9. Waddie
    Waddie Bobtail Member
    28
    104
    Apr 4, 2019
    Depending on fuel, with arch you should be under 90,000 lbs. Blade angled depending on corner bit wear about 11 and change. Best thing is load and scale it somewhere if you are concerned about any scales.
    MartinFromBC Thanks this.
  10. MartinFromBC
    2,769
    12,484
    Oct 19, 2018
    I wasn't sure what truck/jeep/trailer I was going to take, but I will just go with way overkill so I know that weight isn't going to be an issue.
  11. Waddie
    28
    104
    Apr 4, 2019
    Probably don't have to go way overkill, just be comfortable that you have enough axels. Remember you should have 5% variance at the scale. Scale the weight early if possible, takes the guessing out of it.
    lynchy and MartinFromBC Thank this.
