Looking for Options
Discussion in 'Questions From New Drivers' started by newguy76, Feb 20, 2015.
  1. newguy76
    newguy76 Light Load Member
    104
    31
    Aug 14, 2013
    Del Rio, TX
    Hi,
    I have had my CDL A for 1.5 years. I have Hazmat, tankers, doubles/Triples endorsements. I have never done any kind of otr but have been using my license in the West Texas oilfields. I only drive maybe 2-3 days a week while I am working doing FRAC. I make decent money as it is, but don't feel this oilfield type work is for me. I am ready for a change. I think I would like to pull tankers, but not opposed to reefers or flatbed. I have a little experience with tankers because my first job as a cdl holder , I drove a vacuum truck. Down the road I would like to end up pulling fuel tankers, but most reputable fuel haulers want 2 years of OTR. So that brings me to this point. Does anyone have any suggestions as to where I can go to get some OTR experience that pays decent? I live in Southwest Texas, but moving is always an option just depends on the opportunity. TIA
    Chinatown Thanks this.
  3. GasHauler
    6,257
    4,365
    Oct 23, 2005
    Vegas/Jersey
    I'm not clear on what you're getting at. Do you drive now or are you just around the trucks? Hauling fuel is not an easy job to get. The best jobs are taken by the very experienced and it takes awhile to build your reputation. I'm not saying it can not be done just saying it's harder than the rest to walk in with no experience.
    If you have set your goals and are motivated there are ways that will help you. If you know someone that's a big plus if that person is respected. Just about all fuel hauling is local and the companies all know each other. You would think each company would have their own operation but they don't. You'd be surprised on how well they know each other and the drivers that work for them. So reputation is a must and having a bad mark against you is mush worse than OTR driving. Plus these companies look at everything. Your private life will be scrutinize as far as credit and how you handle money goes. I don't believe it's right but they do check.
    Now that you know some negatives you can get around them and move toward the positive side of the work. If you'll completely green let them know. Never try to BS your way into a job like this because they will pick it up in a second. Explain what you do know and how you can adapt it to their way. Never say you'll do it this way because you think it's better. You can do that down the road once you get in. When you're applying they want you to know their way is the best and only way even if you know there's a better way. Go in and apply. Stand face to face and explain you really want to work hauling fuel. You let them know right from the start that you recognize the difference in freight hauling and are eager to learn about the equipment and product. If they tell you they do not hire drivers with limited experience then you ask for their help in seeking a job that will help you fit into their operations. Let them know you want to work for them. Just don't apply and walk out. Go back at least every month and check to see if any thing has changed. Go back in and up-date your application if any item on that may have changed. Like getting certified at any loading facilities. Or driving an oversize tanker. Make them remember you. Keep persistence and you'll get what you want. It's just the in-between jobs that will be tough. Just remember there are not too many tanker drivers that haul gasoline that say they would go back to hauling OTR. Most say it's the best job they have had. But with the good jobs comes the hassle of getting them. Good luck.
    Cali kid Thanks this.
  4. Chinatown
    Chinatown Road Train Member
    77,868
    184,981
    Aug 28, 2011
    Henderson, NV & Orient
    CTL Transportation is hazmat/tankers. Have their own school which is free if you agree to work for them a year.
  5. negativecold13
    negativecold13 Medium Load Member
    364
    419
    Jan 25, 2014
    Gilmer, Texas
