Looking for shop recommendations
Discussion in 'Ask An Owner Operator' started by TruckerPete1990, Feb 23, 2023.
  1. TruckerPete1990
    TruckerPete1990 Road Train Member
    8,623
    5,382
    Jul 16, 2012
    Bentonville Arkansas
    I'm looking for shop recommendations that will swap both rear axles out for different ones. Really looking for one that does all the work like finding the correct set I'm looking for. Anyone have any recommendations? I mainly run the Midwest from Texas to WI and east of 35
  3. NYStarcar
    NYStarcar Light Load Member
    249
    595
    Oct 6, 2020
    In a van down by the river
    Are you looking to upgrade your weight capacity or just looking to swap in newer axles?
  4. TruckerPete1990
    8,623
    5,382
    Jul 16, 2012
    Just swapping to change gear ratios as the ratio I want won't fit in current housing.
  5. boneebone
    boneebone Road Train Member
    2,297
    2,372
    Mar 13, 2009
    What’s your current gear ratio, and what’s the proposed gear ratio?
    What transmission do you have in your truck?
  6. Last Call
    Last Call Road Train Member
    7,568
    45,912
    Mar 15, 2021
    What isypension y do you have ? Guessing its a 1990 379 by your use'r name right ? And what are you looking to change ratios to ?
    And what general area do you live ?
  7. TruckerPete1990
    8,623
    5,382
    Jul 16, 2012
    Got the 400ag suspension I think it's a t680
    Going from 3.25 to a 2.21 or a 2.47 with my 13 speed transmission.
    I live in north west Arkansas but mainly do Midwest.
    Last Call Thanks this.
  8. Ruthless
    Ruthless Road Train Member
    9,184
    91,165
    Aug 28, 2010
    The City.
    what axles can you get 2.21 chunks in?
    Diesel Dave Thanks this.
  9. abyliks
    abyliks Road Train Member
    4,121
    9,707
    May 2, 2010
    ludlow MA
    Are you planning on putting a 4 speed brownie behind it to get rolling or do you just want to cruise comfortably in triple digits?
  10. Diesel Dave
    9,663
    32,738
    Jan 20, 2010
    Hesperia, Ca.
  11. Siinman
    Siinman Road Train Member
    5,515
    14,177
    Mar 5, 2017
    Kansas City, MO.
    Have you done a test and figured out what RPM range you are gonna be with that set up? Better be sure you do not lug that engine as it is not a downsped Engine. Match RPM with TQ and HP Curve of that engine.
    Vampire, Last Call and Opendeckin Thank this.
