Loosing air pressure when engine is running.
Discussion in 'Ask An Owner Operator' started by Aaag, May 17, 2024.
  1. Aaag
    Aaag Bobtail Member
    10
    5
    May 17, 2024
    Tomorrow will block the lines going to airbags and check the pressure.
    silverspur Thanks this.
  3. Constant Learner
    Constant Learner Heavy Load Member
    813
    1,159
    Jul 19, 2011
    The Moon
    Or it's not.
  4. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    I had a 2006 Century with the MBE4000 engine, had an air line come off the bottom of the turbo, think it actuated the variable vanes or something like that. It lost a lot of air while running, zero air loss when shut off, but with the air line off it made so much noise that I was able to track it down. Not at all the same engine as the DD15, but they are both designed by Daimler-Benz.
    The ultrasonic leak detector can be used on a running engine, but it takes some practice to get use to the sounds that you are looking for.
  5. BoostedTeg
    BoostedTeg Road Train Member
    1,886
    3,613
    Jun 2, 2008
    Boise ID
    Check the fan hub I had the same thing on mine couple years ago.
  6. shatteredsquare
    shatteredsquare Road Train Member
    1,407
    1,841
    May 23, 2014
    middle dirt
    just lots of little plastic parts, always breaking = always in stock
    Kenworth6969 Thanks this.
  7. ElmerFudpucker
    7,232
    79,202
    May 17, 2024
    And always replacing… at the worst possible time.
  8. abyliks
    abyliks Road Train Member
    4,178
    9,856
    May 2, 2010
    ludlow MA
    considering they only rolled out of the factory with one to begin with…
  9. Aaag
    Aaag Bobtail Member
    10
    5
    May 17, 2024
    Today disconnected air lines out of secondary tank and blocked fitting connected to the tank .started with blue 3/8 no change the silver one 3/8 YES IT IS the silver one air built very fast and holding pressure for long time .followed this line is going to device on the engine under the turbo from the device blue hose connected to the turbo by using ultra sound device heard noise behind these devices to the engine and to the turbo its hard to hear this leaking by naked ear when engine is running and no bubbles.
    xsetra Thanks this.
  10. Antinomian
    Antinomian Road Train Member
    2,208
    3,498
    Feb 17, 2013
    That's the turbo waste gate actuator. Freightliner won't sell you one (sorry bastids!). They want you to buy a whole new turbo. You can find lots of replacement actuators on line and I'm pretty sure I've seen a video on how to replace it. You will have to remove the turbo though.
    BTW there are completely crazy price differences. I've seen them as low as $45 and as high as $500.
    shatteredsquare and Aaag Thank this.
  11. Aaag
    Aaag Bobtail Member
    10
    5
    May 17, 2024
    Yes when disconnect the harness from VPOD air stop leaking from wastegate solenoid .thank you.
    201773 Thanks this.
