Loosing air
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Strikerhawk01, Apr 29, 2022.
  1. Strikerhawk01
    Strikerhawk01 Bobtail Member
    15 prostar. Cummins isx15 425. Loosing air while parked at night. I can have full pressure in tanks and set the brakes on both truck and trailer. Shut engine off and wishing 2 hours it's beeping at me. Overnight pressure in both tanks will go as low as 30 pounds. It does this with or without a trailer. And I'll be ###### if I can hear or find a leak anywhere. I did change the compressor ( for other reasons) and I changed the brake valve on the firewall in hopes that would solve the problem which it did not
  3. kemosabi49
    10,990
    47,968
    Jan 13, 2013
    SW Arkansas
    You need to get a squirt bottle with some soapy water in it and spray your air lines and connectors. Especially at connectors.
  4. Mike250rs
    Mike250rs Heavy Load Member
    881
    7,081
    Sep 24, 2019
    Raleigh, NC
    Sounds kinda like an air bag or one of the 362538 air line connectors
    Kyle G. Thanks this.
