Loosing oil pressure
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Briggs647, Sep 18, 2018.
  1. Briggs647
    Briggs647 Bobtail Member
    16
    Jul 4, 2017
    I have a 81 Cummins ntc 475 and I’m loosing oil pressure... if I hold the rpms at 17 18 the oil pressure will go up around 45 50 then drop to 35 ish I have changed the oil and both filters I used a scope and and tried to look In oil pan and did not see anything ... I don’t know where or what else to look at ... some have told me that’s normal but I don’t know and have never been around the 475 any help is appreciated thank you
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,551
    6,641
    Aug 26, 2014
    81 is a big cam I? One spin on oil filter on the engine? With an aluminum oil pan. Has a by pass and or pressure relief valve in the oil cooler check that out. Then I would pull the pan. Check piston cooling nozzles and look for bearing problems.
