losing air pressure question
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Allan Decker, Mar 23, 2014.
  1. Allan Decker
    Allan Decker Bobtail Member
    43
    21
    Nov 19, 2009
    montz, la
    05 c15 cat bxs, after air pressure build up and the air purge I and feel air coming from where it purges. Is it leaking back from compressor? These things always confused me.
  3. Heavyd
    Heavyd Road Train Member
    7,826
    6,276
    Feb 4, 2009
    It will purge air for about 20-30 seconds, this is part of the normal purge process. Does it leak continuously though?
  4. Allan Decker
    43
    21
    Nov 19, 2009
    montz, la
    Yes, and if it sits over night I lose most of my air pressure, and when I start truck it's ticks and I have to reach under and push the valve up to stop it so it will build pressure. And after a couple cycles it works properly. But when it hit 120 it's purges, and I still feel air coming out as air pressure drops
  5. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    seems to me air driyer goes bad. it must purge for some seconds.
  6. rank
    rank Road Train Member
    9,919
    113,510
    Feb 11, 2010
    Is it leaking from a round rubber diaphragm about the size of a quarter?
  7. Allan Decker
    43
    21
    Nov 19, 2009
    montz, la
    Yes it's leaking from the round diaphragm. Not purging just can feel air constantly coming from it.
    And after sitting over night, when it's below 90lbs, I have to push that round diaphragm up so it stops dropping air and builds up to 120
  8. chalupa
    chalupa Road Train Member
    3,757
    1,643
    Jul 22, 2010
    Houston,Texas
    Replace or rebuild the drier.....
  9. boneebone
    boneebone Road Train Member
    2,297
    2,372
    Mar 13, 2009
    You do not need to rebuild the Air Dryer, depending on what brand Dryer you have, it has a Turbo Boost Valve or a Purge Valve, some have both. All you need to do is buy the Rebuild Kit for whichever Valve is bad, it's about $45-$50 dollars. All you need a is pair of Snap Ring Pliers and 15 minutes and you can do it yourself. If you look under the Air Dryer you can see the Snap Ring holding the Valve in place. The Instructions come with the Rebuild Kit.
    Allan Decker Thanks this.
