Losing air while bobtail and detached from trailer.
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by rjustin140, Nov 28, 2020.
  1. rjustin140
    rjustin140 Bobtail Member
    Sep 2, 2020
    2015 international prostar Cummins isx15
    like the title says. Trying to chase a new leak. Takes half a day to completely leak out. When I’m attached to a trailer it doesn’t leak. Any suggestions?
    truckdriver31 Thanks this.
  3. daf105paccar
    6,564
    7,294
    Apr 15, 2012
    Trailer air supply line
  4. Rideandrepair
    17,578
    56,942
    Aug 8, 2015
  5. truckdriver31
    6,998
    8,363
    Sep 18, 2013
    you got a leaking dry rotted air bag. the weight of the trailer pushes down air bag. look and spray where the folded part is. top and bottom. when your bobtailing around. the bag is taller. exposing small cracks
  6. magoo68
    magoo68 Road Train Member
    3,393
    5,385
    Jun 11, 2011
    st malo mb canada
    Levelling valve on suspension ..
    Rideandrepair and truckdriver31 Thank this.
  7. Hammer166
    7,617
    27,873
    Aug 18, 2007
    ~8600+' and loving it!
    Ummmmm, air bags run the same height all the time, that's why there's a leveling valve?
    I second the tractor protection valve as the culprit. Anything air suspension related will be worse hooked up due to higher weight / pressure.
  8. Roberts450
    Roberts450 Road Train Member
    2,237
    3,638
    Feb 6, 2016
    They do ride at slightly different heights depending on weight. Its not a big difference maybe a half inch or so, leveling valves aren't that precise.
  9. truckdriver31
    6,998
    8,363
    Sep 18, 2013
    so i guess you never had a dry rotted cab or rear axle bag lose air.
    Rideandrepair Thanks this.
  10. Hammer166
    7,617
    27,873
    Aug 18, 2007
    Plenty. And always worse with higher pressures.
  11. Hammer166
    7,617
    27,873
    Aug 18, 2007
    It's not the weight, it depends more on where the suspension happens to be within the very small dead zone in the center of the leveling valve and/or slop in the linkage. They are a lot more precise than you think, it's much more common to see a loose arm causing varying ride height than the valve itself. I run a carhauler, changes in ride height are quite obvious as low to the ground as I am, and it's remarkably consistent.
