Losing electrical power accessories during left turn?
Discussion in 'Volvo Forum' started by RubyEagle, Feb 28, 2015.
  1. RubyEagle
    RubyEagle Medium Load Member
    632
    790
    Apr 17, 2010
    Just started doing it this morning after flawless 500 + mile run. When making low speed left turns CB (dash mount on 05 VNL) and Sirius XM Roadie plugged into right side dash power point losing power for a few seconds. I have no check light.
    Also a few mins notes ago while on accessories power engine not running my wipers turned on did a single sweep. Have never see that before. Anyone seen these issues before? Maybe a bad ground or CB radio wire loose or a bad relay? Thanks!
  3. JColt
    JColt Bobtail Member
    14
    21
    Jan 9, 2015
    Sounds like wire getting pinched somewhere on steering column when turning wheel to left.
    blr300 Thanks this.
  4. Powder Joints
    8,031
    8,494
    Sep 25, 2007
    Rosamond, SoCal
    Sounds to me like a loose connection, try gently shaking some wires, check to see if the 2 radios are sharing connections.
    Does sound like a big deal just time to chase out a bad install.
  5. blr300
    blr300 Light Load Member
    76
    30
    Jan 5, 2014
    St. Thomas Ont. Canada
    I second the check the steering column....wires are probably stretching around u_joint in the column.Take the cover off under the column and check the wires. Buddy of mine had the same problem.They were wrapping themselves around the u_joint and the wires bared themselves and shorted out. That's an easy fix if that's what it is.
  6. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    Look behind ing. switch at plug in plastic wire holder to be sure it is plugged in all the way?
