We have a Volvo I shift with a 455 engine and she keeps losing power. Shut her off and sometimes it kicks back in again. Changed speed sensor. 4 wire harnesses pipe for def and wires to batteries. Get up to 5 gear in Manuel and kicks out speed and power again. Anyone have any ideas. She's a 2015
Losing power
Discussion in 'Volvo Forum' started by Fid up Volvo owner, Feb 21, 2016.
Is it giving you any codes on the dash?
Yes. A few different ones. First one came up was one for speed sensor so we changed that. Was good for a couple days next one was one similar and they changes 4 harnesses. This one is mid 144 psid 230 fmi 5 which they fixed some going to the battery. But still same problem.
That code come up as software fault
Mine was doing the exact same thing and the problem was the water pump
KB3MMX Thanks this. -
Was it leaking or something?
It went out eventually and I had to get a row. It started out losing power and having to let off the gas then press again to get it to change gears. I felt fully loaded going up hills barely creeping.KB3MMX Thanks this.
Wow that's crazy! Thanks
