Loss of power and acceleration lag
Discussion in 'Ask An Owner Operator' started by thecubantrucker, Aug 9, 2020.
  1. thecubantrucker
    thecubantrucker Light Load Member
    149
    92
    Jun 2, 2019
    no black smoke while idling just minor regular driving black smoke
    bad-luck Thanks this.
  3. bad-luck
    bad-luck Road Train Member
    3,480
    6,407
    Nov 16, 2013
    Baltimore, Maryland
    As I mentioned, did you check and or replace the fuel and air filters?
  4. thecubantrucker
    149
    92
    Jun 2, 2019
    yes just completed a service donde 3 hours ago changed everything im beginning to think it might be electrical
  5. bad-luck
    3,480
    6,407
    Nov 16, 2013
    Baltimore, Maryland
    Ok, I would suggest then that you have somebody plug into the ECM. It's possible one of the ejectors is going bad it just hasn't thrown a code yet, Or the mechanical side of the injectors failing which would not throw a code
  6. thecubantrucker
    149
    92
    Jun 2, 2019
    you might be 100% on the money i was just driving ajd it did this to me 2 times now it was kind of like misfiring when accelerating then it stopped
  7. thecubantrucker
    149
    92
    Jun 2, 2019
    but I don't get why the oil pressure rpm and water temp gauges went out still out
  8. bad-luck
    3,480
    6,407
    Nov 16, 2013
    Baltimore, Maryland
    The injector may not be Spraying correctly or dripping. They can do a cylinder cut out test to help identify which injector is going bad.
  9. bad-luck
    3,480
    6,407
    Nov 16, 2013
    Baltimore, Maryland
    That problem sounds like its electrical, and most likely is not related
  10. Spyro2112
    Spyro2112 Medium Load Member
    643
    447
    Mar 17, 2018
    Fuel pump electronics
  11. nikmirbre
    nikmirbre Road Train Member
    5,617
    10,428
    Jul 27, 2011
    High Point NC
    On my 14L it had these same exact issues. Turns out it was the actuator on the turbo.
