Loss of power and acceleration lag
Discussion in 'Ask An Owner Operator' started by thecubantrucker, Aug 9, 2020.
  1. LameMule
    LameMule Road Train Member
    1,148
    7,418
    Jan 19, 2020
    Montana
    Did the loss of power, misfire and electrical issues happen immediately after your service? If so I'd look at everything that was touched during the service. Was all the air bled from the fuel system after filter change? Was all the air bled from cooling system after coolant flush? What work was done during the service? A detailed list of all work performed would likely narrow down the possibilities if the issues occurred after the service.
  3. Spyro2112
    Spyro2112 Medium Load Member
    644
    447
    Mar 17, 2018
    If air in. The system eventually iyt would work itself out and not be a problem
  4. thecubantrucker
    thecubantrucker Light Load Member
    149
    92
    Jun 2, 2019
    no it was way before the service I think for the power might be injector or turbo actuator and for gauges electrical
    LameMule Thanks this.
  5. LameMule
    1,148
    7,418
    Jan 19, 2020
    Montana
    Yeah, check fuses for the gauges first then look at the harness wherever it passes through firewall or rubs anything. Look for loose connections or abrasions. Did the power loss happen immediately after the new air to air cooler was installed?
  6. Trukdrvr
    Trukdrvr Bobtail Member
    8
    Feb 21, 2019
    Did you figure out the problem? I have 2009 freightliner columbia detroit 60 series everytime it rains or I drive through a puddle it losses power. Turbo stops working and loud ticking noise. I have to shut it off and on again for it to work properly. I have feeling it's ecm since it's attached bottom left of the engine just above the oil pan and gets wet while driving through water
