Lost all power to sleeper after LVD - 2016 579
Discussion in 'Peterbilt Forum' started by mhlvc, May 2, 2020.
  1. mhlvc
    mhlvc Light Load Member
    111
    43
    May 2, 2020
    So as I was trying to fix an issue where none of my front vents are working, I had the truck in contact with the air blowing full power - and then I got a LVD warning. Didnt think nothing of it since I get it a lot, so didnt turn on truck.
    Now all my sleeper power is gone, no lights, fridge doesnt work.
    What could be a fix?
    -Fuse? Should i look at the fuses below the bed?
    -Mega fuse? If there is 1 - where is it located?
    -Bad batteries?
  3. uncleal13
    uncleal13 Road Train Member
    3,797
    6,300
    Apr 9, 2009
    Humboldt, Sk
    Did you restart the engine?
    QUALITYTRUCK Thanks this.
  4. The_young_buck
    The_young_buck Bobtail Member
    Check in your cab fuse panel or bunk for a fuse or a breaker
  5. mhlvc
    111
    43
    May 2, 2020
    So the 2 fuses labeled Powerpoint1 and Cig Light go out and I lose all power to sleeper. I also can’t seem to control the drivers dash above the speedometer. The knob/back button isnt working.
    I have no idea what the problem is now.
    A bad relay?
    How do I check for faulty relays?
  6. Shtruck
    Shtruck Bobtail Member
    Did you find anything out? I’m having similar problems
  7. Shtruck
  8. mhlvc
    111
    43
    May 2, 2020
    Yes I did, when a friend and I were messing around with the fuses below the steering wheel a few days earlier before this happened (trying to see why my front vents dont work, which is another issue completely), 1 of us forgot to put 1 of the fuses back which is a pretty important fuse. I think it was the CECU fuse if I remember, so yeah even when i triple checked all the fuses when I was trying to fix the issue - I guess I kept on missing the fact that 1 of the fuses was missing
