I've talked to someone about my issue already, but still losing power. On flat land truck runs fine. Freightliner Cascadia Detroit DD15. As soon as I start climbing hills I lose power. I get into Billings, MT to do my delivery then take it to I State freightliner. Takes them 2 effing dayz to diagnosis the issue. They finally say injector 2 is leaking. They recommend change all 6 injectors but my boss said change only the one that is leaking. So they change that only 1. We'll I finally get truck back 3 dayz later. I took it in Monday and just got the piece of garbage back today. Well, anyway, get back on I 90 head west and as soon as I get to hills the truck loses all power again. I was like wtf already!! My question here is, can my problem b because I didn't change out all 6 injectors?? Also my oil pressure seems way low. It's reading one line before the 50 mark on the psi gauge. Also I check oil on dip stick and it seems like mayb I have too much oil. Can that b the problem as well??
Lost of power.
Discussion in 'Freightliner Forum' started by jonny 77, Apr 18, 2014.
The oil level rise is probably fuel from the leaky injector..
Loss of power is most commonly attributed to lack of air volume, Turbo, air to air.....Vpod..
..... Philipwore out Thanks this. -
Have you got a turbo boost gauge?
No. I have no turbo boost gauge.
Its a gd piece of crap and probably never get figured out. This the last effing time I have a freightliner.
I appreciate the advice Phil.
Best get oil changed to save extra wear on it.
jonny 77 Thanks this. -
Its defiantly not the Freightliner causing the issue but rather an issue relating to the engine.If you can get a boost gauge it will help pinpoint the issue. A manual one is cheap and easy to plumb in.jonny 77 Thanks this.
Hey KingQ any idea on how to plumb one in? Is there a tutorial that you can link to?
Also, I just read about something called Scan Gauge D. It's a performance monitor. It seems to read boost psi as well as other additional useful info without the need to plumb/install anything. It simply runs a pigtail to your diagnostic port and suction mounts to your dash. Seems like that'd be the way to go.Last edited: Apr 19, 2014
Pitt. power has a kit you just unscrew a allan plug from intake an put in plastic line to gauge in dash.
