low air pressure
Discussion in 'Freightliner Forum' started by guyandsons, Dec 21, 2013.
  1. guyandsons
    guyandsons Bobtail Member
    Dec 21, 2013
    howdy folks. my name is guy ,i have an 07 m2 freightliner with a mercedes engine . about an hour after i got to fort mcmurry i lost air pressure on pri and secondary guages all the way down to about 60psi . it is -38 c here . i stopped and tried to get it to rebuild . both gauges climb at a decent rate but stop at 50 psi . there are no audible leaks
  3. Dieselwrangler
    Dieselwrangler Light Load Member
    128
    92
    Oct 16, 2011
    Edmonton, AB
    Repost to "Trucks [ Eighteen Wheelers ]", this area is for information about the forum itself.
    d o g Thanks this.
  4. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    any sound of compressor cut off (unloader) and noise of air driyer purge?
  5. fuzzeymateo
    fuzzeymateo Heavy Load Member
    771
    783
    May 20, 2013
    AZ
    The governor is probably frozen.
  6. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    yep, i think the same. i'd spill some hot water on governor and I'd change air driyer cartridge and put some spirit ore anty freeze fluid for air systems
  7. guyandsons
    Dec 21, 2013
    thanks for the replies much apreciated ! does anyone have an idea where the govenor is ? thanks!
  8. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    look at air comp. 1st , drier 2ed. air gov. is round with black end.
    guyandsons Thanks this.
  9. KW Cajun
    KW Cajun Road Train Member
    2,383
    3,652
    Apr 12, 2013
    Copperhead Road
    The OP was asking where the governor is, baha. Describing it doesn't answer his question.;)
    The governor is typically mounted right alongside your air compressor. Usually small round/cylindrical shape, as baha said.
    Governnor may have a black cap, as in the first Cat pic, or may have a painted or plastic cap as in the 2nd Freightliner pic.
    In 2nd pic... Red arrow points to compressor, Yellow arrow points to governor.
    [​IMG] [​IMG]
    serozhah and baha Thank this.
  10. G/MAN
    G/MAN Road Train Member
    7,031
    8,625
    Sep 3, 2010
    If you are not building pressure over 50-60 pounds, you are probably losing air somewhere. If it is your air governor, you can sometimes feel air leaking out of the back. Sometimes it is difficult to hear air leaking from the governor. It would be the least expensive thing to replace. The air dryer is another possibility. If it is remaining open then you won't build air. Sometimes a little grit or dirt can prevent the valve from completely closing, so it won't build air. Try sticking your hand underneath the dryer and see if you can feel air leaking. One easy way to check your air dryer is to disconnect the air hoses from the dryer and connect them together. If the air still fails to build, it is not likely your air dryer. If it does build once the hoses are connected, you might try replacing the dryer. Another potential problem is the pressure relief valve, sometimes called the pop off valve. It is located on the side of your air compressor. Once they pop open, they need to be replaced. The valve is usually easy to spot and looks like it is made from brass. At least you are building some air, so it is not likely your compressor. One other thing. Most trucks have pressure release valves on air tanks. You may want to check all of them to make sure they are not leaking. Again, a little dirt can prevent the valve from closing completely. I would put my money on the air governor or air dryer.
    serozhah Thanks this.
  11. guyandsons
    Dec 21, 2013
    thanks so much for all the help. really appreciate it bein -40 an all
    i tarped the entire truck off and bought akerosene bazooka heater
    warmed it up an everything back to normal
    cycled brake line antifreeze thru the truck an wagon .
    will get it into the shop and conduct a full inspection . once again really apreciate the help
    i just got on this site today :)
    KW Cajun and baha Thank this.
