Low Coolant / shut off engine
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by markk, Dec 23, 2021.
  1. markk
    markk Medium Load Member
    566
    197
    Nov 14, 2011
    I had a car with two pitcocks. It had to be jacked up or on hill then crack them open otherwise air stayed in.
  3. markk
    566
    197
    Nov 14, 2011
    I had a freightshaker that did that same thing
  4. markk
    566
    197
    Nov 14, 2011
    Well still a problem. As soon as hot enough to open thermostats the tank fills all the way up. Looks like bubbles on driver side of tank or just maybe from vibration.
    Light comes on at idle for low coolant. Goes out as soon as I drive about 20 feet.
    Float is working .
    I assume both hoses on back of block are outlets so it would not matter if they were switched when installed ?
    If I loosem cap I just loose a half gallon coolant and solves nothing.
    So why would tank full up when thermostats open .
  5. Grumppy
    3,232
    11,400
    Dec 11, 2010
    West Monroe, La
    I know this is a long shot & its a different truck but, just to mention it.
    2019 International occasionally had this issue. One morning I got in it, did my pretrip & light came on. By the time I finished my pretrip, the truck died. I restarted & went to the shop right down the street from us & asked if he could change out that sensor right quick. He said, "Lets try to clean it. Wont take but a sec."
    He unplugged it, screwed it out, had me hold my finger over the hole while he cleaned up the end of it with a shop rag & stuck it back in. Refilled the tank. That's been six months or more & haven't had an issue since.
    May not help you but he said its common. I just thought I'd mention it. Good luck......
    markk Thanks this.
  6. Goodysnap
    Goodysnap Road Train Member
    3,771
    9,195
    Jul 12, 2017
    If the coolant level is above the cold full mark and your warning is going off you need a new tank.
    heater lines out can be swapped, makes no difference.
    markk Thanks this.
  7. markk
    566
    197
    Nov 14, 2011
    Mine is . magnetic. I am thinking my air compressor may have went bad when truck lost water . It is taking a long time to air up the secondary
  8. markk
    566
    197
    Nov 14, 2011
    It fills all the way up and if undo cap will poor out at idle a half gallon coolant .
    Float is floating up with it.
    Wired that light goes out as soon as I start driving. Although coolant level remains full to top
  9. markk
    566
    197
    Nov 14, 2011
    I just started truck. Light was on when I parked a couple hours ago. Light came right on. I idled to 1500. About a minute later it went off.
    I knew I should have just bought another freight shaker . At least it's problems were not this odd.
  10. markk
    566
    197
    Nov 14, 2011
    Any words of wisdom on a aftermarket coolant tank ?
    180.00 to 275.00 .
  11. markk
    566
    197
    Nov 14, 2011
    Video of tank filling up, it will fill all the way full.
    Had to use link since it is too large to upload
    Link Sharing
