Low coolant warning light and bell...
Discussion in 'Kenworth Forum' started by nomad3d, Apr 16, 2016.
  1. nomad3d
    nomad3d Bobtail Member
    19
    We've got a 2011 KW T700 ISX. Low coolant light and bell going off, but coolant is fine. I replaced the sensor and checked the wiring and it looks good. What else should I be looking at and how do I turn off that infernal bell in the mean time?
    Thanks in advance
    Steve
  3. realdesertkickin
    realdesertkickin Heavy Load Member
    925
    752
    Nov 18, 2013
    Tustoned Arizona
    Id overfill it once past the line, just to see if that kills the alarm....
  4. nomad3d
    19
    I've done that too... A few times.
  5. realdesertkickin
    925
    752
    Nov 18, 2013
    Tustoned Arizona
    My pal sent me this...
    Ignition OFF, disconnect the harness connector at the coolant level switch.
    Install a 3A fused jumper wire between the signal circuit terminal and ground.
    Engine running, verify the low coolant indicator turns OFF.
    If the indicator does not turn OFF, test the signal circuit for an open/high resistance.
    If the indicator turns OFF, test the ground circuit for an open/high resistance.
    If all circuits test normal, replace the coolant level switch.
  6. nomad3d
    19
    I think that's a bit beyond my level of knowledge without knowing exactly which wires go where. That and I don't have an ohmmeter.
  7. nasriza
    nasriza Road Train Member
    2,398
    2,074
    Feb 1, 2013
    Chicago, IL
    probably have broken wires between ecm and coolant sensor or maybe bad module if your truck has it for coolant supply voltage to sensor either way i think it's about time for a shop you did all you could.
  8. realdesertkickin
    925
    752
    Nov 18, 2013
    Tustoned Arizona
    I have used paperclip to buypass sensors...
    Ive bypassed the speed limiter, and the engine temp sensor before with no side affects...
    You seem like a smart feller, probably thought of the next 5 things Im gonna think of...so i quit, lol
    Oldironfan Thanks this.
  9. Old school 362
    Old school 362 Medium Load Member
    392
    249
    Mar 6, 2016
    Pensacola Fl
    Is truck shutting down. When alarm sounds
  10. nomad3d
    19
    Nope. Runs fine.
  11. kwcam
    kwcam Light Load Member
    193
    145
    Dec 29, 2012
    at the shop
    On almost all the truck I have seen the problem is a break/open in the wiring just back from the sensor in the rad tank, they vibrate and break inside the insulation so is hard to see, with out a multi meter and doing a wiggle test it may be hard to confirm, should show 5 volts. I normally cut the wires back 6" and crimp on new connectors, but as you say you want an easy fix, not sure on a T700 but behind the center dash panel (speedo/tach) there are little dip switches that can turn off/on alarms sometimes or cover the speaker with tape to mute it for now..
    Rideandrepair and nomad3d Thank this.
