Low fuel in the filter
Discussion in 'Trucks [ Eighteen Wheelers ]' started by bruce25, Jan 16, 2015.
  1. bruce25
    bruce25 Light Load Member
    150
    90
    Apr 16, 2014
    I have been having problems with fuel level in the filter its always low real low where it sucks air when i turn it on and then it stubles and sometimes turns off. Level will always stay low even after 10000 miles of driving. I have changed the fuel check valve at the back of the engine and it made no difference Anyone got any ideas what to look for? It also has developed harder starting where it has to crank for about 5 sec till it catches. After i shut the truck of i have to fill up the filter up so next time i turn it on it doesn't stuble and turn off this way it doesn't suck air. Im at lost so any help will be appreciated.
  3. windsmith
    windsmith Road Train Member
    7,296
    6,032
    Sep 2, 2011
    NEPA
    If it's a filter where the bowl is at the top, then it's not supposed to be full. The level goes up as the filter gets dirty. If it's full, then the filter needs to be changed.
    Air leaks in the fuel system aren't easy to find.
  4. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    what kind of filter? davco?
  5. JohnP3
    JohnP3 Road Train Member
    1,594
    684
    Feb 21, 2010
    Rock Creek B.C. Canada
    You have to give as much information as possible, year, type of truck, manufacturer, type of engine. The more you give the better the advise is.
  6. bruce25
    150
    90
    Apr 16, 2014
    Yes that is the one drop in fuel filter in the glass where it fills up when it gets dirty. Mine never gets full highest i have seen it go was 3 inches of the bottom (TRUCK- 2003 freight liner Columbia with series 60 12.7) So far i have changed fuel line and fuel check valve. What should be looking at next? I should mention after replacing check valve level did raise up to about 80% dirty i then changed the filter and the level problem came back after 3 days of driving with the new filter i can see the bottom of the bowl and i can also see air bubbles. Is it normal to see any air bubbles pushing out? My next thing was to remove and change valves that sit on top of the transmission which are connected to the fuel tanks on both sides?
    I was also going to look at the injectors might need new cups? but it never misses under load it will miss if i sit at the stop light for few minutes then when i leave it might miss for a sec or two and the its goes smooth and i am using Baldwin filters
  7. Helowrenchturn2
    Helowrenchturn2 Medium Load Member
    484
    140
    Apr 23, 2013
    First thing to do is bypass the filter with a sightglass. This will tell you a lot. If there are no bubbles in the glass then the problem is with the filter housing (cracked, bad fitting,etc) if the bubbles remain then the problem is between the tank and the filter. $100 of labor at a shop could save you a lot more money in the long run
  8. bruce25
    150
    90
    Apr 16, 2014
    The glass bowl gets small air bubbles coming out this could be normal im not sure i really can't remember what it was like when it was all normal. I am planning to take it to the shop for overheads injector cups and injectors inspection as a maintenance i will ask them to look in to it and see if they can figure something out. Till then i will be looking at every valve that is connected to the fuel line like the ones i mention on top of the transmission. I was told by a shop that replaced my fuel check valve that there is another one closer to the bowl and if my fuel check valve back at the engine does not fix it i should check it. Which valve is he talking about he said it has a small ball in it and can get stuck any one know where this is at?
  9. Helowrenchturn2
    484
    140
    Apr 23, 2013
    There is a check valve in the inlet side of the filter housing. Remove fuel line then unscrew fitting. Once it's out it will be self explanatory. Pretty simple device. Just a plastic ball held in place with a small spring.
  10. Cowpie1
    Cowpie1 Road Train Member
    5,569
    4,652
    Nov 25, 2008
    Kellogg, IA
    ^^^^ Ding, Ding, Ding.... We have a winner! I have a couple of extra check valves I keep in my parts stash. They are cheap and easy to replace.
  11. pop's
    pop's Light Load Member
    54
    16
    Feb 3, 2013
    Yulee FL.
    If you take off the fill cap off the filter cover an the fuel goes down the check is bad. The filter check valve. Sucking air may be the bottom Oring on filter housing.
