Low oil pressure cat engine 3406b
Discussion in 'Freightliner Forum' started by think, Jul 4, 2013.
Whats the serial number first #,s 3 is all.
I don't know the serial number. It's a 1996 Freightliner.
a lot of money spent to still have the same problem.
If you dont know the serial # and arrangement # how will anyone know how to help you? Its on the cold side of the block, on the head, near the firewall. A brass tag permanently affixed, write it down and save it.
The serial # prefix would help, but I have a few other questions to. Does it have Jakes? Did you just decide it needed overhauled and oil pump or did a reputeable mechanic? Have you checked the oilpressure relief valve? Also a B is not a overhead cam eng has anyone checked cam bearings did they plastigage the rods and mains to measure for proper clearence which should be done anytime you are in a engine with oil pressure concerns. A 96 should have an E model I think which is overhead cam could be a whole other set of issues so really need serial # to be sure what we are dealing with
Look on your truck registration look for VIN # or look @ vin # outside the door next to the company name Dot # Etc. and if you need the Engine serial # you have to open the Hood and look on the side of the engine block (Driver side ) above your fuel pump or air compressor for most trucks
Happy 4th -
Its on the block
It most likely a 5EK 1993 through 1997 the longest production serial # of the E's
Check gauge ?
