Low oil pressure
Discussion in 'Ask An Owner Operator' started by liljim, Sep 9, 2019.
  1. liljim
    liljim Bobtail Member
    31
    4
    Jul 31, 2018
    I have a 2006 International 9900 with a Cummins isx I just had a head gasket job done 2 weeks ago because I had coolant getting in the oil. The head checked out find and the egr cooler check out good. Today my low oil pressure light and yellow check engine light came on. Oil pressure was 20 going down the way and drop to 18 when I let off pedal. Fresh oil change and new head gasket. Truck is not running hot
  3. xsetra
    xsetra Road Train Member
    5,196
    7,147
    Aug 21, 2011
  4. Ridgeline
    22,724
    123,386
    Did you by the way have the oil analysis done?
    You may have bottom end issues.
  5. snowwy
    snowwy Road Train Member
    20,612
    13,333
    Jul 6, 2009
    Could be poor quality oil.
    Maybe time for oil pump and new bearings.
    If sensors don't fix.
    Engines don't like water in oil.
  6. liljim
    31
    4
    Jul 31, 2018
    Thanks guys, I think I will try oil sensor and oil filter first
  7. snowwy
    20,612
    13,333
    Jul 6, 2009
    Get an oil sample.
    Another thing would be blowby test.
    Different motor but I drove a cat with broken piston rings. Needed an oil change every 2 weeks. The blowby was diluting the oil and ruining it. Causing low pressure to the point the lights would come on.
    77fib77 Thanks this.
  8. liljim
    31
    4
    Jul 31, 2018
    Did you drive it while the light was on?
