Low oil pressure
Discussion in 'Volvo Forum' started by Giovanni, May 28, 2022.
  1. Giovanni
    Giovanni Bobtail Member
    33
    9
    Dec 7, 2016
    I have a 2012 d13 volvo vnl670.
    Oil pressure went down to 28lbs at idle.runs 50+lbs when driving 14to1500rpm.just started yesterday not sure what to do.any help would be appreciated.
    D.Tibbitt Thanks this.
  3. AModelCat
    164,850
    Never trust the dash gauge.
    Go to a shop and have them put a test gauge on it before you do anything else. Then compare the test gauge reading to Volvo's specs.
    Lots of folks have pissed away thousands of dollars on bearing rolls, oil pumps etc when it was just a failing pressure sensor.
    Longhaullover and D.Tibbitt Thank this.
  4. D.Tibbitt
    157,241
    Im not sure where ur pressurr sensor on a d13 is located but i just changed mine on my isx because my gauge was going bonkers. Normal is about38 psi. Well it would shoot up to 100 then down to 60 then down to 0. Then flucuate between 30 and 40 constantly... Opened the hood and checked the sensor and there was oil dripping off it ,meaning it was bad. 90 dollars. Changed it out. No more problems.
  5. Giovanni
    33
    9
    Dec 7, 2016
    Will do
    Thx
  6. nasriza
    nasriza Road Train Member
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    I dont see what problem is d13 runs 25-35 on low idle hot engine 1500 rmp high idle between 50-60 psi, so to me nothing looks out of norm with hot engine as you are describing.
    NWAF and AModelCat Thank this.
  7. Giovanni
    33
    9
    Dec 7, 2016
    Thanks for the info.
    The engine always ran at 30-35 psi at idle.always above 30psi.
    Noticed a difference yesterday.
    Also i noticed when i put on engine brake psi would go down.
    And right back up when disengage .thx
  8. Longhaullover
    Longhaullover Bobtail Member
    11
    12
    Jul 2, 2020
    hows your oil level? If it stays constant, I would change out the sensor because most likely it will be at fault providing false readings.
    not an expensive thing ans super easy to change. even if you take it to a mechanic that will cost you more than this. so try this out and see if it fixes it
    77fib77 Thanks this.
