low power....
Discussion in 'Ask An Owner Operator' started by omer, Dec 6, 2012.
  1. omer
    omer Bobtail Member
    14
    Dec 6, 2012
    Atlanta GA
    hello i am new to this so plz bear with me.
    i have a 2006 volvo 670 with volvo d12 engine 710xxx miles egr's and egr cooler disconnected, my boost pressure is 31psi@1900rpm and my fuel 68psi@1900rpm but the truck still lacks the power. the mec says to change all 6 injectors and see but to me thats a big gamble about $3500 and i am not so sure that would fix it. if any one has any ideas please let me know.
    thank you
  3. VisionLogistics
    VisionLogistics Road Train Member
    1,551
    978
    Dec 8, 2011
    Jellystone
    I'd start with a dyno to get tangible numbers on the performance before dropping $$$ on 6 injectors. Failing injectors will present other symptoms besides retarded performance.
    omer Thanks this.
  4. Tuzla075
    Tuzla075 Light Load Member
    60
    17
    Dec 4, 2012
    Is it ultrashift?
  5. omer
    omer Bobtail Member
    14
    Dec 6, 2012
    Atlanta GA
    no it's a 10 speed straight meritor transmission
  6. omer
    omer Bobtail Member
    14
    Dec 6, 2012
    Atlanta GA
    can you tell me what other symptoms i would have if the injectors were failing
    thank you
  7. VisionLogistics
    1,551
    978
    Dec 8, 2011
    Jellystone
    I'm not real familiar with the volvo engine but some common symptoms of injector failure are:
    - Unstable engine speed
    - Poor fuel economy
    - Runs rough / missing
    - Audible engine knock (fuel knock)
    - Air in the return fuel
    To name just a few. Have you done a cylinder performance test yet? If so what were the percentage numbers?
  8. nikmirbre
    nikmirbre Road Train Member
    5,608
    10,411
    Jul 27, 2011
    High Point NC
    Poor fuel mileage.......And a dyno will tell you nothing, no good reason to get a dyno.....
  9. omer
    omer Bobtail Member
    14
    Dec 6, 2012
    Atlanta GA
    no i have not done a cylinder performance test yet
  10. omer
    omer Bobtail Member
    14
    Dec 6, 2012
    Atlanta GA
    and i am not sure if volvo dealer would do one with the egr's being disconnected
  11. TripleSix
    134,014
    Has it always been this way? If it has, I would wager that someone cut it back more than than 10 percent
